2K2 Sunroof Owners - Try this
Old Aug 6, 2002 | 07:41 AM
maxatlast's Avatar
This is the second/third time this has happened.
Slide the sunroof switch back about half way, wait a while and then slide the switch to close. On a few occasions mine will not close. I have to open completely and then close.
Anyone else experienced this or similiar ?
Old Aug 6, 2002 | 07:48 AM
bootone's Avatar
yes, I have experienced the same thing. Sometimes you have to open it all the way and then close it. Sometimes, if I am closing the sunroof and cut the car off it will sometimes stop and sometimes continue to close. The manual says that the windows and sun roof should continue to close on aux power
I am going to have this checked the next time I take it in
Old Aug 6, 2002 | 08:05 AM
carguyrob's Avatar
Mine does the same thing. I think that switch is very easily confused.
Old Aug 6, 2002 | 09:10 AM
AIX's Avatar
AIX
same here..
Old Aug 6, 2002 | 09:13 AM
maximadave's Avatar
detailerdaveb@gmail.com
ditto
Old Aug 6, 2002 | 11:07 AM
hollywood7301's Avatar
yup.
Originally posted by maximadave
ditto
Yup.
Also, mine isn't sealing quite right anymore. I have to use the "vent" switch to adjust the sunroof at speed to get a good seal.
Old Aug 6, 2002 | 11:55 AM
Triple8Sol's Avatar
I miss the .org!
Yup, some sunroof issues here too.
Old Aug 6, 2002 | 11:57 AM
Padsy's Avatar
Boost.....
Mines f-ed up too.....
Old Aug 6, 2002 | 12:13 PM
DrVolkl's Avatar
ditto
Yup...noticed that for awhile now...it gets confused.
Old Aug 6, 2002 | 01:02 PM
Pmm3rd's Avatar
I have the same problem once in a while. I read somewhere on this board some time ago that the motor in the Maxima sunroofs are weak and the dealerships have been replacing them under warranty (if they fail completely).
Old Aug 6, 2002 | 03:33 PM
Greg's2kGLE's Avatar
I think once you open a door, the aux power cuts off. At least on my 00 it does.
Old Aug 6, 2002 | 03:53 PM
MetaOrbit's Avatar
Got Projectors?
Mine does the same thing guys. Sometimes it just won't respond.
John
Old Aug 6, 2002 | 05:46 PM
F23A4's Avatar
uh huh,same here
Old Aug 6, 2002 | 08:04 PM
phillyguy's Avatar
There is something funny w/ the sunroof switch. IF the roof is open and you move the switch too quickly to close it(like flicked it w/ your finger) it fakes to sunroof out and it doesn't close at all. Then you have to open and close the switch again to get it to shut. Now I make sure to move it slowly now, and it works fine.
Old Aug 7, 2002 | 01:01 AM
mingo's Avatar
Re: 2K2 Sunroof Owners - Try this
i was playing with a 2k2 at the dealership and it did the same thing, i thot i broke it.
Old Aug 7, 2002 | 05:20 AM
Padsy's Avatar
Boost.....
Re: Re: 2K2 Sunroof Owners - Try this
Old Aug 27, 2002 | 02:02 PM
Tripower's Avatar
Double Ditto
Same deal....found that "bug" the day after I bought it. As long as you move the switch slowly, seems to be OK. The swith has a "cheapy/flimsy" feel to it compared to my 97's switch.
Old Aug 27, 2002 | 04:28 PM
MaximaDisciple's Avatar
Mine too
got that problem also
Old Aug 27, 2002 | 04:48 PM
asu174's Avatar
Clay Aiken has fancy genitals
I seriously forgot I even had a sunroof with this damn heat......
Old Aug 27, 2002 | 05:35 PM
CJLax's Avatar
Crappy sunroof switch
We have a 2k2 Pathfinder at home. The switch on the sunroof of the Pathfinder is far superior to that of the Max. Maybe they should replace all the switches on our Maxs to those found on the Pathfinder.
Much sturdier feel.
Old Aug 27, 2002 | 09:06 PM
ABS's Avatar
ABS
Re: Crappy sunroof switch
Much sturdier feel.
Do they look interchangeable?
Old Aug 28, 2002 | 12:18 AM
2001SE's Avatar
yah....maybe you can buy off sepretley the panel in the pathfinder from the dealer and switch it with the crappy 2k2 one
Old Aug 28, 2002 | 04:54 AM
BioMaxDDS's Avatar
sunroof problems here too
Old Aug 28, 2002 | 06:54 AM
Kojiro_FtT's Avatar
My sunroof used to open on it's own. And it happened once on the expressway in January. I'm in Rochester, NY. Snow comes tumbling into the car while I'm going 65. Great.
The dealer said they couldn't find any problems, but they "re-ran the wires and fiddled with all the connections." I was like "Great, so they did nothing." But surprisingly it stopped happening.
I do get the confusion problem too. Problem is, it's probably not a problem with the switch, but with the cpu.
Old Aug 28, 2002 | 07:56 PM
ABS's Avatar
ABS
You think it's a cpu or a code/software problem?
TallTom
57
Oct 14, 2025 05:16 PM
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
