Oil Change Procedure Question
Old Aug 7, 2002 | 05:54 AM
steelymatt's Avatar
Hi,
I drained out all of the oil and removed the filter. I want to pour some clean oil down there to clean out the engine. If I pour it in at this point, will the oil drain out where the filter goes or will it come out from the drain pan?
Thanks,
Matt
Old Aug 7, 2002 | 06:03 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
I sure hope it comes out of the lowest point in the vehicle, which would be the oil pan......
Crusader's Avatar
Hmm, never tried that, but my first assumption would be it will come out the drain pan, and not the filter.
Old Aug 7, 2002 | 06:06 AM
karguy's Avatar
Re: Oil Change Procedure Question
Originally posted by steelymatt
Hi,
Thanks,
Matt
Oil will come out of the drain pan. Filter is feed by oil pump so engine would to be running for the oil to come out where the filter is located.
Be well!!!!
Old Aug 7, 2002 | 06:35 AM
Mark S.'s Avatar
If it will make you feel better, put the new filter on before you pour that quart of oil in. But the oil should come right through and out the drain plug.
Old Aug 7, 2002 | 07:38 AM
buzek's Avatar
Clean it out good!!
Why don't you pour about a pint of gas down there..that should do the trick.
Old Aug 7, 2002 | 07:58 AM
bill99gxe's Avatar
Old Aug 7, 2002 | 07:59 AM
jjs's Avatar
jjs
Originally posted by bill99gxe
Well 'said'!!!
Old Aug 7, 2002 | 08:02 AM
buzek's Avatar
How's that saying go?
Ask a stupid ?.....
kmitchel
Oct 30, 2016 05:28 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
Johnny9595
Sep 3, 2015 05:18 AM
tnewbs
Aug 28, 2015 10:15 AM
maxinout93
Aug 20, 2015 02:17 AM
