Supercharger 101, what do I need and dont need?
Old Aug 12, 2002 | 02:06 PM
  #41
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: Re: ...
Originally posted by Y2KevSE
Hmmm..... I wonder if that's possible.... should be.
New mod, Kev?
BTW, does the Stillen kit come with a regular or Super FMU? If regular, wouldn't you be able to tune the A/F curve withOUT the need of the SAFC by upgrading to the SFMU?
Old Aug 12, 2002 | 02:15 PM
  #42
iansw's Avatar
Re: Re: Re: ...
Originally posted by IceY2K1
New mod, Kev?
Like Stillen would ever give out the better of two products that have the same function.
IanS
Old Aug 12, 2002 | 02:20 PM
  #43
BigDogJonx's Avatar
Hehehe... do you believe what you think is right, or do you believe me? Yeah, I have the same one.
16 points, 8 for hi-throttle and 8 for lo-throttle. Per Keven97se, don't adjust the lo-throttle points because the ECU will relearn itself.
So you have 8 RPM points and you can do them in 500 RPM increments... so you can pick points like this:
1000
2000
3000
4000
5000
5500
6000
6500
which gives you 8 points.
Ok that makes sense. But I thought you have adjusted the low to like -29 or -40%. Or was that the High (the lowest point on high?) So when if the a/f is too rich at that level and you want to decrease it? do you just do everything on the high setting and leave low flat?
Dixit
Old Aug 12, 2002 | 02:29 PM
  #44
IceY2K1's Avatar
Re: Re: Re: Re: ...
IanS
Not give out, but you may be able to "upgrade" if asked/paid for.
Old Aug 12, 2002 | 03:45 PM
  #45
Y2KevSE's Avatar
Rice Boy in Denial =)
Re: Re: Re: ...
New mod, Kev?
Regular FMU. Super FMU is $278.
With the SFMU, you can get only get a general a/f curve... meaning, if at 6000 you are 11.6:1 but the other points are 12.4:1, you can't do squat about it.
Old Aug 12, 2002 | 03:51 PM
  #46
Y2KevSE's Avatar
Dixit
Nope, you're thinking about something else. There's a hi-throttle point and lo-throttle point you can adjust. Let's say I set lo-throttle to 30% and hi-throttle to 60% (the numbers are made up, don't use these). If your throttle percentage (basically, how much you mash the accelerator) is between 0 to 30%, the AFC will not do anything. From 30% to 60%, it will use the lo-throttle settings. If you mash the pedal hard enough and go over 60%, the AFC will use your hi-throttle settings.
To get around the ECU assimilating the adjusted a/f, 39% for lo-throttle and 40% for hi-throttle should be used, per Keven97se.
Yes, when a/f is rich, you want to decrease the number.
Yes, adjust the hi-throttle points and leave all the lo-throttle points at 0.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Cumalot
Nov 28, 2000 09:38 AM
