PIAA
Old Dec 17, 2000 | 06:26 PM
mphilips's Avatar
Hello , i just got the piaa super white platinum series H4 bulbs 60/55w. Did I get the wrong ones, whats the difference with super plasma.
Old Dec 17, 2000 | 06:35 PM
MaximaZero's Avatar
Needs non-Maxima Friends
as long as theyre H$ size, they should work. the diff between the two is that plasmas are not as bright and have more blue/purple color to them.
Old Dec 17, 2000 | 06:51 PM
mphilips's Avatar
Yes I put them in, I didnt notice any difference with stock, except for the slight blueness.
Do you know the kelvin rating for the super white / super plasma for the h4?
I did buy the h3 55w super white for the fogs.(didnt put in yet)
Old Dec 18, 2000 | 11:05 AM
mphilips's Avatar
i just put in the super plasma, though I didnt get a kelvin rating on them.
Hey guys , dont mean to be stupid but, how do you take of those rubber screw nuts which hold the splash guards, so you can install the H3 fogs?
Old Dec 19, 2000 | 06:55 AM
psing23's Avatar
u gotta get under the car... unscrew the 3 screws on each side and pop out the 3 plastic pushers on each side too... just get a flat screw driver and stick it in on the side and pull it down... they should just pop out... u dont have to take off all the plastic from under the car... u could just take off the left side and just slide/turn it out of the way and then do the same on the right side... no need to take the plastic off in the middle... then u have to unscrew the BLACK screw that is facing down right where u removed the plastic... do not touch the white/silver screw cause that one is just to adjust the light..
Old Dec 19, 2000 | 01:13 PM
Maximizd's Avatar
One more thing....
..you *may* have to forcefully remove the fog lamps through the front opening of the car by tapping on the whole assembly with something like a hammer - those bad boyz were in there pretty tight and after you remove that final screw, they still may not budge without some additional "persuasion"!
Old Dec 19, 2000 | 02:18 PM
psing23's Avatar
actually hammer isnt really needed... what has to be done is after you unscrew the fog lamp you look at the top right hand corner of the fog light assembly (thats for the left side, for the right side its on the top left hand corner of the assembly in the back)there is a plastic thing that has like a + shape in it and in the middle is a metal thing that goes in there... just push in that metal thing with a screw driver and the fog light assembly should fall out... just make sure to put ur hand on the other side cause it will fall out and fall on the floor and break. also remove the wire/plug before u pull it out...
Old Dec 20, 2000 | 08:15 AM
mphilips's Avatar
thanks for all the help guys,
H3 Fogs
but I had a hard time putting in the left side, then the right side was more difficult, even with screwdriver and hammer, finally I went to the dealer and he finished the job. Its tough to work when its freezing outside. He charged me 30 bucks.
Like the lights though.
Old Dec 20, 2000 | 07:04 PM
GetSome681's Avatar
I really want to put some new headlamps in my max. Do you guys really recommend this setup or what? Is there a big difference in the amount of light? Or, do they at least put out the same amount of light, but look more like xenon bulbs? I think that I'm just looking for that cool look. Any help or comments would be totally appreciated. Thanks
Old Dec 26, 2000 | 07:50 PM
mphilips's Avatar
Yes the lights are brighter, you can tell when you drive past everyone, and check out their lights.
Old Dec 26, 2000 | 08:05 PM
y2kse's Avatar
I'm not so sure that they're brighter . . .
But they're certainly whiter. My wife's GXE has stock bulbs and while they seem to be about as bright as my 60/55w Super Whites, they have a definite yellowish cast to them. I vastly prefer my PIAAs.
Old Dec 28, 2000 | 01:42 PM
GetSome681's Avatar
Lights installed
Got the H4s Plasmas in, and it took a while to install the fogs. Finally got them in...once I figured out what I was doing, piece of cake. Installed the passenger side one in less than 10 minutes.
They look awesome..I love it!!
Fbana41
Aug 29, 2016 12:18 PM
Mustang1999
Dec 20, 2000 08:15 PM
Maxima-Ness
Dec 19, 2000 02:26 AM
Shingles
Dec 6, 2000 12:11 PM
2000MaximaSE
40
Nov 5, 2000 02:41 PM
