18x8 47mm offset work? help wanted
Old Sep 12, 2002 | 09:17 AM
2000 SE's Avatar
I am thinking of getting a set of wheels, but I am not sure if 18x8 w/ a 47mm offset will work.
Old Sep 12, 2002 | 09:55 AM
UMD_MaxSE's Avatar
Got Bent?
47 offset is a little high.... if it rubs, you may need spacers.... but maybe it will work fine....
Old Sep 12, 2002 | 10:36 AM
2000 SE's Avatar
How does the number work? The larger the number the further in the wheel goes, or the larger the number the further out the wheel goes?
Old Sep 12, 2002 | 11:42 AM
MarcusJY's Avatar
Correct. If you want the wheel more flush with the fender you want a lower offset # than stock. But not to low because then it will rub, I would say between 35-38.
jerrod99_se-l
Aug 27, 2015 08:27 PM
doctorpullit
Aug 20, 2015 05:15 PM
twotonezed
Aug 16, 2015 11:41 AM
MikesChevelle
Aug 9, 2015 11:50 AM
kenc15
Aug 5, 2015 08:29 AM
