Why is my car SLOWER then when it was STOCK??? *timeslip included*
Old Sep 16, 2002 | 09:59 AM
K Pazzo 6's Avatar
Ok when I was stock I ran a 15.9**....(I have the timeslip at home so I'll post all the detailed stuff for this time later)
Now I went to battle of the imports yesterday to check out the cars & they said you can enter your car in the 'fun run' for $25 more to see your times....so i said what the hell why not, its been over a year since my last run....and this is what I get (me manually shifting was worse...16.3**) :
R/T- 1.005
60'- 2.446
330- 6.823
1/8- 10.387
MPH- 69.61
1000- 13.435
1/4- 16.048
MPH- 86.82
Ok I'm pretty sure I didnt spin either....I go around the water when coming up to the line.....I have it revving around 2000 till I see the 3rd yellow light & gun it...also I have an auto & just leave it in drive w/ o/d OFF.
Changes on my car from over a year ago when I ran a 15.9....I have 18" Mille Miglia's, Body Kit, Leather Seats, Stillen Exhaust, Frankencar Midpipe, w/ JWT Pop Charger (and lots of minor crap that dont really add weight).
P.S. - I had my stock airbox on my car & when I decided I will run the car-- fellow org member 'BriGuyMax' helped me install my midpipe & JWT popcharger in the lot. Something I remember is that going down the track in 2nd gear it wasnt shifting till 6500??? I'm thinking that the ecu was still programmed w/ what I had on earlier & I should of reset the ecu by disconnecting the battery??? What do you guys think it is????
Old Sep 16, 2002 | 10:05 AM
CO2kmax
18 rims, or mabey less low end because of exhaust, diff outside temp. Just guessing. Or mabey your car was just having a bad day.
Old Sep 16, 2002 | 10:13 AM
K Pazzo 6's Avatar
it was the perfect day....little sun but COOL
Old Sep 16, 2002 | 10:17 AM
2kSeattleMax's Avatar
Did you have the chromies on it when you ran before? Adding that much rotational weight could have an impact.
Old Sep 16, 2002 | 10:21 AM
K Pazzo 6's Avatar
yes I had the chromes on before....but dont understand what u mean by 'rotational weight could have an impact'?
Old Sep 16, 2002 | 10:25 AM
Adding wheel weight adds parasitic loss...takes more HP to make em spin, thus lowering your times.
Old Sep 16, 2002 | 10:30 AM
Blu's Avatar
Blu
the tits
i'm almost positive its the 18" wheels. I ran on a crappy weather day and my best was a 14.89 then switched to 15" and ran a 14.64 with the same exact 60' times. Yes i had slicks but i was hooking good and pulled a 2.19 both runs. I think I still have my slips to prove if you don't believe me.
Old Sep 16, 2002 | 10:37 AM
K Pazzo 6's Avatar
well I'm going again this saturday....i'll have the ecu reset by then...then i'll see if its the rims or not
Old Sep 16, 2002 | 10:56 AM
Cumalot's Avatar
You ran with the 18" Mille Miglia's? Aren't those suppose to be quite heavy? Heavy wheels make a big difference.
Old Sep 16, 2002 | 11:15 AM
ohboiya's Avatar
I agree with Cumalot ... the MM's aren't performance rims ... not sure which you have .. but the Evo's are about 26 / 27 lbs ... they may be roughly the same size as stock which are 17's .. but it takes more to get 18's going than 17's ...
Need something lightweight .. my Volks are 18's but only 16 lbs ... but I'll probably run the same times even though they're lighter b/c they're 18's ...
Old Sep 16, 2002 | 11:35 AM
K Pazzo 6's Avatar
i have evo 5's....oh i see
Old Sep 16, 2002 | 12:49 PM
CIRCO's Avatar
Yeah K Pazzo its definately the rims...I felt the same way you did when I ran my car with the heavy @ss Moda R6's.
Old Sep 16, 2002 | 12:58 PM
K Pazzo 6's Avatar
damn...when discount tire was trying to sell these to me they said they are racing rims & even though they are bigger they are lighter then my stock by far
but i never ordered from them & wound up getting a deal from a fellow org member in my area & he sold me his MM Evo 5's is $950 a good price for a set of evo's 5 that are 2 month old w/ 2 month old tires (245/40/18 kuhmo ecstata...or something like that)?
Old Sep 16, 2002 | 01:27 PM
CIRCO's Avatar
Thats funny! Even the box for my Moda's have "Lightweight racing rims" on them, but I know at almost 30lbs they are not light!
Old Sep 16, 2002 | 01:31 PM
BriGuyMax's Avatar
dude....your 60' sucked BAD...check what your 60' was on your "stock" run....and that may tell you why you ran slower.....oh yea...and the rims...
Old Sep 16, 2002 | 01:48 PM
Y2KSESteve's Avatar
Doesnt the body kit add another 30 - 40 pounds painted?
Old Sep 16, 2002 | 02:30 PM
K Pazzo 6's Avatar
Old Sep 16, 2002 | 02:33 PM
K Pazzo 6's Avatar
i know....i'll post the stock timeslip tonight when I get home to compare
p.s.-- if i can go back to a year & half when I bought this car I would get a stick....or maybe i should consider a conversion like y2kev
Old Sep 16, 2002 | 02:35 PM
K Pazzo 6's Avatar
true, from what i heard...for every 100 pounds thats a .10 sec off/on (whether you take off weight/or put weight on)
Old Sep 16, 2002 | 04:18 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Maybe 10lbs. at the most.
Old Sep 16, 2002 | 05:34 PM
slickrick's Avatar
i heard the same thing, eevry 100 lbs= .1 off
Old Sep 16, 2002 | 05:50 PM
UMD_MaxSE's Avatar
Got Bent?
this is the rule of thumb for big hp RWD muscle cars... for our cars, weight is even more of a factor than this...
Old Sep 16, 2002 | 05:55 PM
UMD_MaxSE's Avatar
Got Bent?
BTW, how are your ignition coils? I swapped mine out 6 months ago and it made a pretty big difference... there is a TSB on them, but unless the engine is pinging, the service dept probably wont do a thing... I swapped mine out myself...
Old Sep 16, 2002 | 06:23 PM
Y2KSESteve's Avatar
Yea he's right, when I ran with my 150lb buddy in my car my time went up almost 3 tenths
Old Sep 16, 2002 | 07:17 PM
slickrick's Avatar
wow, looks like when i race ill be racing solo. i had no idea fwd cars are more sensitive to weight. but wouldnt more weight on the front wheels give better traction off the line?
Old Sep 16, 2002 | 07:43 PM
K Pazzo 6's Avatar
sorry...i'm home now & have been looking for the timeslip & cant find it...i know i scanned & had it on my computer but my computer went crazy couple months ago & best buy put a new hard drive which wiped out everything i saved...oh well...my car is just slow i guess & i suck at running at the drag strip
Old Sep 16, 2002 | 08:28 PM
AznWontonboy's Avatar
Your a 2k2.
Old Sep 16, 2002 | 09:18 PM
Y2KSESteve's Avatar
Might help a bit right at the start, but the rest, well....
Old Sep 24, 2002 | 07:22 PM
SkylineGTR's Avatar
well big powered RWD cars, every 100lbs is .1 faster, but those big powered RWD domestics were in teh neighborhood of almost 4000lbs, the lighter the car gets, less weight makes more difference. On a 4000lbs car 100lbs may be .1 seconds, but on a 2600lbs civic si, 100lbs could be almost half a second. Have tried that, my friends civic si vs my auto 2k, and we run side by side, he beats me by a 1.5 car lengths to 90, but with 1 150-200lbs person in his car, i beat him to 90 by almost 2 cars.
Old Sep 25, 2002 | 06:26 AM
stose95's Avatar
I noticed a big difference when I replaced my 15 inch gxe rims with the oem 17inch. and just by hand the 17's were much heavier than the 15's
Old Sep 25, 2002 | 12:44 PM
Black VQ's Avatar
Okay...
We already established that the bling-bling 18s and the body kiy aren't helping. My question to you is...How many times did you run stock? It could just be a consistency thing, considering there's only .1 of a difference. Assuming the worst, your performance might be identical or just a little better than stock. Since there isn't a world of difference in performance, consistency could be the problem.
Lakersallday24
Jun 16, 2019 01:35 AM
jskirwin
Jun 8, 2016 08:49 AM
kingw323
20
Oct 21, 2015 08:36 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
