oil
Old Sep 18, 2002 | 11:58 AM
Larrio's Avatar
The Definitive AE Master
oil
i searched under synthetic oil, oil changes, etc and even the FAQ section but couldn't find exactly the thing I was looking for. I need some advice on what type of synthetic oil to use during my next oil change for a 2k1 max at 23,000 miles... 5w30? Thanks in advance.
Old Sep 18, 2002 | 12:02 PM
njmaxseltd's Avatar
Re: oil
Were you looking for somebody to actually pour it in your crankcase for you?
There's so much info on oils on this forum it's scary. Download the oil analysis spread sheet.
Mobil 1
OR
Amsoil
There's your choices.
Old Sep 18, 2002 | 12:05 PM
kirzan's Avatar
Re: oil
It kinda depends on where you're located. Nissan recommends a 5w30 in the manual. If you're in a warmer climate you might not need the extra startup protection of the 5w -- so a 10w30 might be fine. Personally, I'd never go above a 30w oil on a VQ engine unless I was racing in the desert. Mobil1 and Amsoil seem to be good choices for synthetics.
Old Sep 18, 2002 | 12:10 PM
iwannabmw's Avatar
Amsoil
Old Sep 18, 2002 | 01:24 PM
Horus's Avatar
No Redline Oil for you Maxima guys?
I have run it in the SE-R for years. Just wondering...
BTW just got the 2k GLE that is why I’m poking my nose around learning from the combined wisdom. Well I guess I'm a Maxima guy now.
Old Sep 18, 2002 | 01:34 PM
iwannabmw's Avatar
Redline's a great oil, but Amsoil is more geared toward wear protection and is a superior oil in that area. If I competed with a car were every last bit of power was needed, and I rebuilt my engine frequently, I would lean more towards Redline, even though it's way more expensive.
Old Sep 18, 2002 | 03:48 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
It's quite overpriced for what it does. Unless you are blown by a S/C or turbo or NOS, Redline is way overkill.
Use Mobil 1 oil.
If anyone is interested in learning about how oils do in our cars follow the pretty link in my sig.
Old Sep 18, 2002 | 04:44 PM
iwannabmw's Avatar
That's not pretty, it's just a text link. Come on Bill, spice it up a little already
Old Sep 18, 2002 | 04:49 PM
kramerica72's Avatar
I was a mechanic for years and had great luck running Mobil 1 in just about everything. Amsoil claims to be even better in tests, so if you choose one of the two you can't go wrong.
Old Sep 18, 2002 | 04:54 PM
iwannabmw's Avatar
There's info in Bill's spreadsheet as to why as well. I also some more info about if people are interested.
Old Sep 18, 2002 | 05:08 PM
Larrio's Avatar
Re: Re: oil
Mobil 1
OR
Amsoil
i guess I phrased my question wrong in the sense that I only wanted to know the viscosity of synthetic to run in my car and not what brand as I already know mobil 1 and amsoil are the biggest names around here for our engines.
Maybe you could pour it in for me when you have the time Thanks to everyone else for their info
Old Sep 18, 2002 | 05:14 PM
Re: Re: Re: oil
You will be safe with 5w30 pretty much year round unless you are in some very extreme climates.
Old Sep 18, 2002 | 06:15 PM
Deven2kStickMax's Avatar
Re: oil
mobil 1 all the time
Old Sep 18, 2002 | 10:26 PM
slickrick's Avatar
so is 10 w 30 ok for florida climate. i live most of the year in north central florida, and i put 10-w30.
Old Sep 19, 2002 | 05:36 AM
bill99gxe's Avatar
Yep.....10W/30 is just fine.
Old Sep 19, 2002 | 06:31 AM
Virus's Avatar
Amsoil 5w-30
www.motor-oil-bible.com It'll give you all you ever needed to know about oil. Amsoil ranks best in many areas. Mobil didn't fair so well, but both are excellent oils.
Old Sep 19, 2002 | 07:02 AM
iwannabmw's Avatar
I know we’ve beaten viscosities to death before, but I don’t think we’ve ever looked at it this way. If we have, I’m posting it again anyway
People have mentioned that the pour points and borderline pumping temperatures of the 5W-30 vs. 10W-30 is almost identical, so a 10W-30 should be just as usable in cold weather as the 5W-30 for this reason. Those two numbers don’t tell the whole story.
When an oil is graded a 5W or a 10W, a test called the cold crank simulator is used to measure the oil’s apparent viscosity. The test is done at progressively colder temperatures for the lower grades. Just looking at Amsoil, the 5W-30 has CCS viscosity of 2555 cP at –25C. The 10W-30 has a CCS viscosity of 3444 cP at –20C. The 10W-30 is 35% more viscous than the 5W-30 at a temperature 5 degrees warmer. At 40 degrees C, the difference in viscosities is only 10%, but the point is if the engine is in the desert in the summer time, the 5W-30 will still allow faster start-up protection than the 10W-30. Drop the ambient temperatures down to the 40 F number that I see thrown around, and it stand to reason that the 10W-30 will still be thicker than the 5W-30, hence the 5W-30 will still offer better start-up protection and fuel economy.
I realize the differences are getting a little technical at this point, and all the numbers still blow conventional oils away, but I wanted to point out that there are differences from using a 5W-30 vs. 10W-30 even in warm climates. In the grand scheme of things does it really matter and will we as owners ever see them in terms of wear over the lifetime of the engine? I doubt it, and I’m not saying it’s a bad idea to use 10W-30 either. The post was more for people who say there’s no difference between the two as temps. warm up. There is, albeit small one’s compared to dino oils.
Old Sep 19, 2002 | 07:11 AM
bill99gxe's Avatar
Originally posted by Virus
Amsoil 5w-30
Recent analysis results of Mobil 1's SuperSyn formulation are quickly deteriorating the credibility of that article/book. It's not the terrible oil that people (myself included) feared it would become. I disagree with a percentage of what it says. The rest is mostly common sense found by searching Google.
Old Sep 19, 2002 | 07:17 AM
bill99gxe's Avatar
Yes, you have beaten it to death.
It depends on which hair you want to split. You can also say a 10W will sit on your actual engine parts better instead of completely draining in the crankcase since it is a thicker oil and thus you don't need that extra start protection when cold....
Since I rarely see ambient temps outside of 30 to 80 degrees in my garage (where my car sits and where almost all of its cold starts take place), using 10W/30 is justified in my book, especially given I have 130k on my VG. My VQ, with 50k or so, still gets 5W/30.......
Old Sep 19, 2002 | 08:16 AM
iwannabmw's Avatar
I agree, at this point it's splitting hairs. I just wanted to put some more technical info behind the whole argument, you know, for people who might want to search for it later.
Old Sep 19, 2002 | 05:37 PM
yep i would think so too, because he is in the sunshine state.
Old Sep 19, 2002 | 05:51 PM
Green_2's Avatar
My next oil change will definately be Amsoil. I've read some pretty bad reviews concerning Mobil 1...
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
