6 spd tranny problem
Old Sep 19, 2002 | 05:03 PM
6SPD_HLSD's Avatar
Here is what happens:
Take off in reverse spiritedly, not too crazy though and there is a clunk in the tranny. Put it in first, take off hard enough that you are on the threshold of loosing control and the same clunk. No slippage at all. No noises at any other time. It sounds like if something falls/slips in place due to torsional loading and then it engages. Can not be felt, only heard.
I would appreciate some thoughts/speculations of what it can be. Please no “Take it back under warranty” replies because I will.
It’s 2002 6-spd hlsd.
Old Sep 19, 2002 | 05:07 PM
TimW's Avatar
The silent but deadly Moderator
hmmm, sometime the calipers will do that.. are you sure its from the tranny?
Old Sep 19, 2002 | 05:27 PM
6SPD_HLSD's Avatar
I was told by Nissan it is the tranny. they used their instruments to listen to it. I think I heard the calipers before but those are not as loud. The tolerances on the sliders are quite tight. This sounded like there is an 1/8" "backlash" for lack of a better term.
Old Sep 19, 2002 | 06:48 PM
ABS's Avatar
ABS
Have you had the transverse link recall completed?
Old Sep 19, 2002 | 07:35 PM
2002Maxxxima's Avatar
You sure it's not an engine mount? Something's moving around in there.
Old Sep 19, 2002 | 09:35 PM
6SPD_HLSD's Avatar
I did have the transverse link recall done.
Old Sep 19, 2002 | 09:50 PM
190hpKiLLA's Avatar
Granny Driven
Maybe niSSan forgot to tighten something?
Old Sep 20, 2002 | 09:49 AM
6SPD_HLSD's Avatar
Or maybe the worker forgot a chopstick while having lunch on the line.
Old Sep 20, 2002 | 11:24 AM
Blue 2k1 se's Avatar
Are you sure it is not yhe exhaust bumping the underside of the car? Sometimes it hits the bottom of the car when you torque up the engine on a launch.
Old Sep 20, 2002 | 12:15 PM
Kojiro_FtT's Avatar
Do you have a FSTB? Wasn't there clearance problems with some models where it would clunk when first put into gear?
Old Sep 20, 2002 | 01:35 PM
6SPD_HLSD's Avatar
No FSTB. Completely stock.
Old Sep 20, 2002 | 03:15 PM
2kseman's Avatar
only if it's the metal type...
Old Dec 12, 2002 | 02:56 PM
99/00 I30t's Avatar
Yet another Maxima Problem. I am starting regret trading in my 2k I30t for this 2k3 maxima. Oh well you couldn't get a 6-sp in the I35.
Old Dec 12, 2002 | 08:22 PM
Newman's Avatar
realize that people tend to only post their problems. when was the last time you read a post saying "i got in my car to go to work this morning and everything was fine!"?
no car out there is perfect. some will have problems.
you have an awesome car. there is nothing to regret.
Old Dec 12, 2002 | 08:25 PM
99/00 I30t's Avatar
I don't regret it but since I got the car I have been through three 02 sensors and having to take the car in all the time is getting to be a hassle.
I like the car its fun to drive and decently quick, I don't know, I guess I expected a little more from Nissan quality.
Old Dec 12, 2002 | 08:31 PM
Richard Scott's Avatar
Ok I will say it - I got into my Max this morning and went to work and everything was just dandy. I loave driving this car. My 2KGLE has had only one little problem (bad O2 sensor - replaced by great Nissan service). There are no rattles, squeeks, wind noise or any TSB issues. Just a great dependable driving machine. I couldn't be more please in an automobile.
Old Dec 12, 2002 | 08:35 PM
Newman's Avatar
i guess its just hard for me to see where some people are coming from. i have not had a single major problem with my car. i had to take it in twice because my sunroof drainage tube got disconnected then the same thing happened with my AC condensation drainage tube. ive been very happy with my car. maybe thats why i feel like i should defend it.
Old Dec 12, 2002 | 09:16 PM
emax02's Avatar
If I go over about 10 MPH in reverse the stick will pop out of reverse and go into nuetral. I of course get a big clunk when this happen's. I thought this was normal in 6spd 2002 max's? Hmm, I always figured nissan did this on purpose to keep speeds low in reverse... lol.. So the rest of you can go say 20 in reverse with your 6spd's?
I beleive Frankencar Steve's max does the same thing, after hearing this I thought for sure it was normal.
Old Dec 13, 2002 | 05:00 AM
For the record: I got into my car to go to work this morning and everything was fine! (And always has been)
Old Dec 13, 2002 | 01:31 PM
ABS's Avatar
ABS
Hmmm . . . I'll have to check this out.
Old Jan 9, 2003 | 06:10 PM
6SPD_HLSD's Avatar
Just want to let you guys know it was a loose engine mount bolt.
Old Jan 11, 2003 | 12:18 PM
ABS's Avatar
ABS
Re: 6 spd tranny problem
I have the same problem with my 2K2. I have 24k on the car and it just started about 3k miles ago. I have only noticed in first, but I need to check reverse to see if it happens there as well. I only hear the "clunk" right after clutch engagement and under full or near full throttle. I am suspecting an engine mount . . . or possibly an undertightened wheel, or undertightened hub/drive shaft bolt . . . The only thing is that the drive shafts fit into the hub with splines so this seems unlikely . . . It could also be a worn CV joint . . .
I have also had the recalled control arms replaced and have had my clutch/flywheel replaced under warranty as part of the recall on those parts.
I brought the car into the dealer to have it checked out, but it was right after a snow storm and full throttle acceleration in first lead to a lot of wheel slippage so they couldn't replicate the problem . . .
Let me know if you figure this one out, so I can get the same repair . . .
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
