Unorthidox pulley
Old Dec 24, 2000 | 02:25 PM
MarshMan's Avatar
anyone have the pulley? does it do a whole lot? is it more for lower rpms or can u tell? cheaper to go through them than stillen or what?
Jonathan Marsh
Old Dec 24, 2000 | 04:52 PM
y2kse's Avatar
Check out . . .
http://www.unorthodoxracing.com/ultras.html
Also, run a search under the following:
Unorthodox
Pulley
UDP
Cheers!
Old Dec 25, 2000 | 07:12 AM
got rice?'s Avatar
Jonathan Marsh
It's most likely cheaper to go through an UR distributor rather than direct from UR. Stillen is just one of their distributors. Shop around!
You should feel more torque in low and mid range rpms.
Old Dec 25, 2000 | 10:13 AM
y2kse's Avatar
Hey Phuong . . .
What's your current price on the UDP for the 2K Max?
Old Dec 25, 2000 | 08:16 PM
got rice?'s Avatar
Re: Hey Phuong . . .
I gotta check on my pricing, but it's probably going to be priced around $169
Old Dec 25, 2000 | 10:49 PM
y2kse's Avatar
Has anyone ever heard of a UDP blowing up a crankshaft ???
I read in another post that the pulley acts as a vibration damper. If the crankshaft is even slightly unbalanced, reducing the weight on the pulley could cause the crankshaft to break. Has anyone ever heard of this happening on a Maxima?
Old Dec 26, 2000 | 03:22 PM
got rice?'s Avatar
Re: Has anyone ever heard of a UDP blowing up a crankshaft ???
If you guys frequent the Z forum (www.twinturbo.net) then you would know I'm not a big fan of the underdrive pulleys. yeah, it's a great bang for the buck but long term reliability is still an issue. I don't like the idea of swapping out a big, heavy stock pulley and putting in a lighter one. The vibes/frequencies from the accessory belts travels through the pulley into the crank. the VG30DE/TT (Z32 engines) are also internally balanced on the crank, so most *should* be fine, but they're risking an $7000-8000+ engine for 12-15 rwhp. Not worth throwing a rod if you ask me. I still sell them if the customer *really* wants it.
Old Dec 26, 2000 | 03:59 PM
y2kse's Avatar
Yikes !!!
I must say I don't like the sound of that at all, Phuong. Point taken.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
