Winter tires....Can you give me advice please...
Old Oct 25, 2002 | 12:14 PM
TheOzzfather's Avatar
I am going to get the Blizzaks(sp) the 99mp3 speed rating tires. Going to get them off of tire rack.com. I only need to put them on the front tires correct? And how should I rotate my other tires.
Do I REALLY REALLY need to get tires for winter? Are the Protenzas that bad?
Old Oct 25, 2002 | 12:19 PM
jjs's Avatar
jjs
Re: Winter tires....Can you give me advice please...
If you live where it snows, you should ALWAYS get a set of 4 snow tires for ANY vehicle. It is not just a matter of traction for accelerating (be it FWD or RWD) or even traction and steering (FWD).
for a balanced car, especially during that all important braking, you need 4 snows.
Wasim521's Avatar
Yes Potenzas are that bad...I've never heard of the logic of putting tires only on the front wheels. I would assume you would have to put the same on all four, for accurate speedo readings or something. But don't quote me on that...
Old Oct 25, 2002 | 04:32 PM
spta97's Avatar
Definitely get the set of 4. The car is balanced better and will perform much better in the snow. On one of my old cars I was told to get tires that were skinnier than the ones I had. The reason for this is a narrower tire will actually create more pounds per square inch and dig into the snow where the wider tire will float on top of it. It helped ALOT!
You can also get a different set of rims with the snows so you can change them yourself and protect your good rims from the winter. Another option is to get a beater car. With the price of tires nowadays, its almost cheaper. If you put the beater as your primary car on your insurance it might be cheaper like mine is
Old Oct 25, 2002 | 04:36 PM
95emeraldgxe's Avatar
all four tires.......pay 300 extra and prevent a 8000 dollar accident
Old Oct 25, 2002 | 04:48 PM
LeoB's Avatar
gotta have 4
check any website where they talk about tire safety, and they will tell you it is unsafe to mix and match tires. Different adhesion qualites, different handling characteristics would combine to spin you out not only on snowy or icy roads but even more so on the dry road days when handling with snows becomes trickier
Old Oct 25, 2002 | 05:17 PM
max988's Avatar
I have driven my FWD vehicles ( Nissan, Toyota, Honda, Acura) without the snow tires in MN. You will be okay with the factory four-season tires unless you drive fast in a snowy day like it is just another dry summer day
Old Oct 25, 2002 | 06:22 PM
Cwa232's Avatar
The Potenza's are a blast in the snow... if your in an empty parking lot. I have the Dunlop Wintersports. The difference is night and day. I'll never be without dedicated snow tires again. Definately get 4.
Old Oct 26, 2002 | 07:14 AM
I used to do that...
But I didnt pay $29000 for a car I cannot drive in the winter.
Old Oct 26, 2002 | 07:16 AM
Hey max988
Welcome to the fourms! Where in MN are you at?
Old Oct 26, 2002 | 02:33 PM
ABS's Avatar
ABS
I'd like to get a pair of old 16" rims for my SE for use with winter tires. Any suggestions on where/how I could find them . . . it should also drop the cost per snow tire . . .
Old Oct 26, 2002 | 04:06 PM
BugNout
Check sig for tires.
$260.00 for all four.
Old Oct 26, 2002 | 06:56 PM
ABS's Avatar
ABS
You have mail.
Mahmuth
Aug 16, 2024 08:23 PM
mclasser
22
Nov 12, 2020 01:58 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
