NEED Help w/vibrating steering wheel
Old Nov 2, 2002 | 01:55 PM
SoloMaxima
ok..my rotors are warped and still haven't gotten it fixed yet....and when i drive at about 65 and above my left side of the steering wheel vibrates...maybe the whole steering wheel....i don't know if its due to the warped rotors...or maybe my left tire doesn't have enought air...the left tire does seem a little deflated...
anyone know what is causing my steering to vibrate..??
thanx..
Old Nov 2, 2002 | 04:12 PM
augie's Avatar
Check your tire pressure on all wheels. It might be that.
Old Nov 2, 2002 | 04:21 PM
krazyd's Avatar
Re: NEED Help w/vibrating steering wheel
thanx..
I'm having the same problem with my 2001 now. I only have 18k miles on the car, is possible that I have warped rotors? If I bring my car to the dealership will they fix the problem?
Old Nov 2, 2002 | 04:57 PM
SoloMaxima
Re: Re: NEED Help w/vibrating steering wheel
i'm not sure...but i'm gonna bring my car in to get the warped rotors fixed...they should fix it under warranty...bring a copy of the tsb also..
does your steering wheel vibrate when you brake from 65 and up..?? or just when you drive fast..??
mines vibrate when i brake and when i drive fast(65 and up)..
Old Nov 2, 2002 | 05:08 PM
kafene's Avatar
thanx..
Most likely the rotors. Mine does the same. People installing your wheels should torque them ON (doesn't matter when they take them off), but most (if any ) don't do this.
BTW, you're right, there is a TSB for it.
kafene.
Old Nov 2, 2002 | 05:29 PM
2kmaxse's Avatar
kafene.
If the vibration occurs when braking then it is the rotors. But if just while driving approx above 60mph then it is the balancing. Good luck....
Old Nov 2, 2002 | 05:42 PM
the paragon's Avatar
definetly rotors. it happend to my steering wheel, jutters and vibrates. I'm planning to get a set of the Cross-drilled rotors from the GD.
Old Nov 2, 2002 | 07:36 PM
krazyd's Avatar
This problem occurs in my 2k1 Maxima whenever I brake. It feels like I have to force the pedal to floor in order to stop my car, plus the leftside of the steering wheel shakes real bad. I actually don't like driving my car when it's raining outside b/c i'm scared that I won't be able to stop. Anyways, do you think I should bring my car to the dealership and have them replace the warped rotors with new ones? Also, does anyone have this TSB in a *.PDF file so I can present it to them when I bring in the car?
Old Nov 2, 2002 | 07:39 PM
kafene's Avatar
what group deal?
Where are you guys getting the rotors from? and how much?
kafene.
krazyd,
Regarding the TSB, I'm sure it's on the web somewhere, although I don't know where. If you want a PDF, I can scan a print out and send you a PDF, but that won't be until Tuesday PM at the earliest.
kafene.
Old Nov 2, 2002 | 07:42 PM
krazyd's Avatar
I would buy the Brembo Cross-Drilled/Slotted rotors from South West Autoworks, but considering the fact that the car was bought brand new in February of this year, I want Nissan to fix the problem. The car has only 14k miles on it and rotors are messed up already. That's unacceptable in my book.
Old Nov 2, 2002 | 08:05 PM
BLaZin 2k MaX's Avatar
My **** is the opposite, When i get past 75 im cool but when im stuck in traffic which is typical in LA my **** shakes like crazy. It started after i changed my springs which im sure is the problem but damn im starting to say **** it, I want to put my stock springs back on and screw the wheel gap at least ill be driving smooth.
Old Nov 2, 2002 | 09:00 PM
Re: what group deal?
kafene.
krazyd,
kafene.
http://forums.maxima.org/showthread.php?threadid=132897
$200 for a set of four plus shipping
Old Nov 2, 2002 | 09:41 PM
krazyd's Avatar
Re: Re: what group deal?
I rather get the Brembo rotors...
Old Nov 2, 2002 | 10:50 PM
augie's Avatar
Do they sell any for the 2k2 maxima?
Old Nov 3, 2002 | 12:23 AM
SoloMaxima
i can find the tsb for the 2k but not for the 2k1...is it the same and will it work...?
does anyone have the tsb for the 2k1..?
Old Nov 3, 2002 | 12:33 AM
K Pazzo 6's Avatar
On my '01 I noticed that my stock 17's were causing my steering wheel vibration between 45mph-75mph...I have 18's now & no problem....& when I put on my aftermarket 17" winter rims I have no problem either...so from my experience I pointed the finger at my stock 17's
Old Nov 3, 2002 | 06:03 AM
krazyd's Avatar
I don't think a dealership will take a 2000 Maxima's TSB and use it for the same problem on a 2001.
Old Nov 3, 2002 | 09:00 AM
SoloMaxima
yea, your right..i'm just gonna bring it in without the tsb and see if they will fix it under warranty...
Old Nov 3, 2002 | 01:41 PM
2kmaxse's Avatar
WHAt they may do it either resurface the old rotors and replace the pads or both alltogether. The initial problem w/ nissan oe rotors is that they were to thick originally from the factory therefor the disipitation of heat is retained causing rotors to warp. I wouldn't be to concern about finding the tsb, most dealers aware shameful problem. But u may encounter a d!ck at the counter, and that's when u come back w/ tsb and throw in their face. In regards to getting brembo is your best bet, most likely it will occur again. But get Nissan to fix first.....
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
