Adding tweeters to BOSE?????
Old Nov 3, 2002 | 11:02 PM
2k1maxgle's Avatar
I was wondering if it is possible to add a set of tweeters to the BOSE system. Can you tap into the existing tweeter wires and then worry about where to run them? i just wanna know if it is even possible. a friend of mine wants to try this in his 2k, and i didnt know if it would work or not so i figured hell it never hurts to ask.
thanks in advance!
Old Nov 4, 2002 | 07:47 AM
Kal's Avatar
Kal
Re: Adding tweeters to BOSE?????
Im sure you it can be done. Im thinking of changing my front tweeters out for some JL Audio tweeters. Is he going to put these in the rear? if so where exactly.
thanks in advance!
Old Nov 4, 2002 | 08:07 AM
TimW's Avatar
The silent but deadly Moderator
if you read in the audio section, they say the tweets are 4 ohm.. so, replacing them with 4 ohm drivers has no effect on the bose or stock system other than better quality highs.
Old Nov 4, 2002 | 08:11 AM
Virus's Avatar
Just be prepaired to have a hot glue gun on hand to mount the new tweeters. It's very tight behind the pillar and you'll have to do a little shaving.
Old Nov 4, 2002 | 04:50 PM
2k1maxgle's Avatar
Re: Re: Adding tweeters to BOSE?????
he wants to add a set in the front....i may also do this now that i know its possible. if i do it i might add some for the back too....i dunno where would be a good location but i can figure something out. thanks for the info!
Old Nov 4, 2002 | 05:07 PM
asu174's Avatar
Clay Aiken has fancy genitals
Adding front tweeters is a piece of cake. Pop the A-pillar off and you're set.
Adding rear tweeters is pointless. It will throw your stereo imaging off, as high frequenices are supposed to come from the front of the car. Most competition cars don't even use rear speakers, let alone tweeters.
Old Nov 4, 2002 | 05:11 PM
TheOzzfather's Avatar
What is the best way to pop those pilliars off???
If they are that easy then I assume that the front door speakers are not that hard to replace as well?!?!?!
Old Nov 4, 2002 | 11:31 PM
maseo77's Avatar
i did
i tapped tweeters to the front stock tweeters and added 2 more to the rear door speakers for a total of 6 and the result is a wonderful "cluster Fu#K" of sweet sound. i cant believe i didnt do it sooner, if i let you hear my setup you will do it too. btw i got 2 10" subs in the rear too.
Old Nov 5, 2002 | 03:49 PM
CHAZMAX's Avatar
I'm planning on getting some tweeters also. One more question...
Does the depth of the tweeter really matter. I would assume it does.
The one's I'm lookin at is http://www.crutchfield.com/cgi-bin/S...nfo&i=108K105T ...and the "flush mount depth" is 1-3/16". Is this too wide to fit flush behind the pillar?
Old Nov 5, 2002 | 06:19 PM
Virus's Avatar
My tweeters are the Diamond Audio Silk's which are 1" in depth. 1 1/4 is pushing it.
Old Nov 5, 2002 | 09:05 PM
2k1maxgle's Avatar
viruswhere did you get your tweeters?? and for around how much? also maseo77, do you have any pics of where you have all your tweeters mounted?
Old Nov 6, 2002 | 07:10 AM
CHAZMAX's Avatar
Thx Virus!
So I guess 1" depth would probably be most to go w/out taking a chance, huh?
Good info...
Old Nov 6, 2002 | 07:15 AM
saxdogg's Avatar
You know, most of these posts have just said "just pull out the a-pillar and you're set"
Anyone got a good write-up with pics? (Or know where one is?)
ARFF?
Old Nov 6, 2002 | 08:32 AM
TimW's Avatar
you have to very carefully pry from the top trying not to deform the plastic or headliner. It does just pop out.... well out and up.. or something like that.
be sure to do the anti-rattle foam while youre in there.
Old Nov 7, 2002 | 12:08 AM
maseo77's Avatar
sorry i have no pics, but if you want to meet up i will gladly show you, and help you mount yours.
Old Nov 7, 2002 | 01:45 PM
2k1maxgle's Avatar
tweeter pics
hmm...no pics...well that sucks! and i doubt we can meet up, where are you located?? IM from SC. so meeting to do the job might be a little difficult!
Old Nov 7, 2002 | 02:23 PM
asu174's Avatar
Re: What is the best way to pop those pilliars off???
Yup, pretty easy, although not AS easy....
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
