Removing middle air vents
Old Nov 6, 2002 | 11:33 PM
PoppaZ
I have a rattle between the clock and top part of the middle air vents. What is the easiest way to remove the middle air vents safely?
Old Nov 6, 2002 | 11:48 PM
BigDogJonx's Avatar
Re: Removing middle air vents
Just grab the vents and pull out and slightly upwards.
Dixit
Old Nov 7, 2002 | 12:52 AM
PoppaZ
Re: Re: Removing middle air vents
Dixit
Just grab the vents with my fingers and pull? How do you grip on?
Old Nov 7, 2002 | 08:14 AM
BigDogJonx's Avatar
Re: Re: Re: Removing middle air vents
Just grab the inside of the bottom of the vents.
Dixit
Old Nov 7, 2002 | 12:04 PM
Phydeaux's Avatar
Wrap a flat screwdriver in a shop towel and (carefully!) pry upwards btwn the stereo and the vent. Alternate prying btwn left and right a little. It shouldn't take much to loosen.
Old Nov 7, 2002 | 12:10 PM
SHPatel's Avatar
I got this same cracking noise as well. What is the fix...do we just put some padding in between the vent and the dash? Just curious.
Old Nov 7, 2002 | 12:16 PM
PoppaZ
I think so. I'm going to take a look in there and pad that **** up.
Old Nov 7, 2002 | 12:22 PM
Larrio's Avatar
The Definitive AE Master
yep, same problem here.. it's annoying. I might take it to the dealer cause there are tsb's for the rattles
Old Nov 7, 2002 | 12:36 PM
PoppaZ
I did that and it came back. At this point the best bet is to open it up yourself and pad it up.
Old Nov 10, 2002 | 05:29 PM
SR20DEN's Avatar
VQ Wizard
Jam a crowbar way down it's throat then twist real hard and yank it all out. If you don't hear the sound of ripping plastic then you need to repeat the procedure.
Old Nov 11, 2002 | 10:51 AM
irvine78's Avatar
why don't you just take it to the dealership and get that fixed?
Old Nov 11, 2002 | 01:58 PM
Colonel's Avatar
Old Fuddy Duddy
ROFL
phew...that was a good one.
Old Nov 11, 2002 | 02:19 PM
Y2K2Driver's Avatar
Go to my homepage and then the dash removal pdf. It doesn't give you great instructions on how to get it out, but does show what is holding it there.
DJLAX152
May 4, 2021 11:46 AM
Smackasmith
Feb 1, 2016 12:40 AM
RWCreative
Sep 21, 2015 11:01 AM
bumpypickle
Sep 20, 2015 08:22 AM
lux97Max
Sep 4, 2015 05:42 PM
