Is it worth $450 for a remote starter and alarm for my Max???
Old Nov 7, 2002 | 06:52 AM
TheOzzfather's Avatar
Its brand name Black Widow. It has door pins and hood pins as well as a LCD remote that lets you know the status of the car at all times. Naturally I have to ditch the factory alarm in order to get the keyless entry they tell me. Im confused.
Old Nov 7, 2002 | 07:02 AM
TimW's Avatar
The silent but deadly Moderator
its worth $450 to have extra protection (as there is almost none with the factory alarm).
You dont need hood or door pins, but a back up hood pin is a good idea for the NJ/NY area.
Remote start is tricky on a max. If these guys are telling you that stock alarm is removed or disabled, then they dont know what they are talking about.. go somewhere else. Your new alarm will control the factory alarm. Almost all decent alarms have factory alarm arming/disarming.
Also, being that remote start is so difficult on the max, I wouldnt consider it with a off brand alarm.
Old Nov 7, 2002 | 07:15 AM
Well how is it trickey???
It is at Best Buy. Black Widow is a major brand BTW. They tell me that in order to get the remote start to work on max I have to disable the factory alarm. SO then I would be out whatever protection the factory offers plus keyless entry. That is why they suggested the remote starter with alarm. And the pins come with the alarm.
Old Nov 7, 2002 | 07:24 AM
acMAX's Avatar
IMHO
it aint worth it
Old Nov 7, 2002 | 07:29 AM
TimW's Avatar
Then you need to speak to a different installer there, they are obviously very clueless. I wouldnt let someone touch my car that was talking that nonsense.
You cannot disable the SECU. There is no way around it. If they were to try to get around it, the SECU would see the door lock activated by the aftermarket alarm and the factory alarm will set. It will think you locked it with the key. So, to get back in your car, the new alarm has to disarm the factory. Not really an easy way around that.
The tricky part about remote start is that tach wire inside where many installers try to tap will not give accurate feedback to the alarm. You may get a grinding starter or starting only some of the time. Depends on the alarm really...
Pretty sure that alarm is a DEI alarm, so I think the alarm itself will work fine. A knowledgable installer is gonna make or break this deal...
Old Nov 7, 2002 | 08:33 AM
Boy oh boy am I super confused now...
Now I really have no clue what to do! Why is this stuff so darn confusing? So you are saying I can keep my OEM alarm and have the keyless entry work through the remote starter thinggy you hold in your hand? Thanks for the info TimW it is very much appreciated.
Old Nov 7, 2002 | 08:58 AM
TimW's Avatar
Your new alarm will send commands to the SECU (that is also a major part of the factory alarm and just about every other function your car has). The SECU coordinates everything from your headlights to trunk release to dome light.
Your new alarm will tell the SECU to unlock the doors, lock the doors and arm/disarm the factory alarm. Generally, the factory alarm arms when the door is locked.. So you *need* an alarm that will trigger a disarm... If they dont know that, then they havent done a maxima. if they havent done a maxima, I wouldnt want to be their first. The DEI install sheet says all this. You can find a copy for yourself in the Audio section...
Old Nov 7, 2002 | 10:18 AM
Funny...
The type of alarm I am now looking at is DEI. This is what they told me at Audio King, a bit better place and naturally more expensive. They will install the remote starter. The bypass they install is so the OEM alarm is bypassed when the car is remote started, otherwise the car will not start. Now being that the OEM alarm is activated when the lock button on the keypad is pushed, the alarm will not activate from the aftermarket keypad when the lock button is pushed. Do I make sense now TimW? That is what I ment by bypassed. So I really do not want to carry around two keypads. They suggest (sales naturally, and extended warr) that the factor alarm does not provide much protection so go with a remote start w/alarm, $500. That way when the lock button on the AM keypad is pressed it triggers the new alarm and the factor one is bypassed. Now I have to make a decision is this all really worth it?? What do you think Tim, and again thank you for your assistance.
Old Nov 7, 2002 | 12:42 PM
TimW's Avatar
oh... yeah.. they arent bypassing it.. they would be deactivating it by some channel's output, I'm sure the DEI alarm can do that. Actually, what they are doing is using a key transponder to make your ignition think your chipped key is there. so to answer your questions, if they do it correctly, your new remote controls the new alarm AND the factory alarm. The new alarm will know when to deactivate/reactivate the stock alarm.
Old Nov 7, 2002 | 01:37 PM
That is it pretty much...
I forgot about the key transponder part. So is it worth it?
Old Nov 7, 2002 | 02:18 PM
black2kmax's Avatar
go for the new DEI Viper or python with the transponder LCD remote. DEI makes the best alarms hands down and they are worth every $$$ spent. Here is the Python one for sale on Ebay -
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1872110512
Check that out and you'll see that it is the most BADASS alarm on the market.
Old Nov 7, 2002 | 02:27 PM
see5's Avatar
Are you sure this is all worth it + $450? It sounds like a very easy project to abandon.
Old Nov 7, 2002 | 02:35 PM
TimW's Avatar
Any decent alarm will be ~$200+
any decent install will be $100
adding autostart is always at least $100
NVIS transponder (immobilizer) = ~$50
there's your $450
if you have HIDs, aftermarket *anything*, live in a climate with extreme hot or cold, then yes.. very much worth $450
Old Nov 7, 2002 | 02:37 PM
Tanman's Avatar
I think it's worth it. Everyday when I start my car and the engine's cold, I have to sit there for 3 minutes for it to warm up. It sucks. I'm getting the remote start so I can turn it on from the bottom floor, and by the time I get up to the floor I'm parked on, it's ready to drive.
Also, the aftermarket alarm and alarm pager gives me some peace of mind.
Old Nov 7, 2002 | 07:39 PM
Thank you to all and Polo for the PM.....
It is great to have a resource like you guys around!! Thank you again.
Old Nov 7, 2002 | 08:32 PM
soundmike's Avatar
Very sound, Mike
There's currently a good deal on Groupbuycenter.com for that Aladdin which IIRC TimW has or was talking about in the past.
http://www.groupbuycenter.com/buy.asp?row_id=7304
Old Nov 7, 2002 | 09:17 PM
TimW's Avatar
nah, I have an Autopage 750
Old Nov 7, 2002 | 09:19 PM
soundmike's Avatar
Very sound, Mike
i guess i don't "IIRC"
Excalibur23
Oct 13, 2015 04:33 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
