Side marker removal ?
Old Nov 9, 2002 | 04:14 PM
wolf0's Avatar
Does anyone know how to remove both the front and rear side markers without breaking the clips. Or is anyone familar with a link hear or anywhere else that explains this.
Just got my clear corners and tring to figure it out!
Old Nov 9, 2002 | 04:15 PM
Ramius83
Try posting this thread in the appropriate "Generation" under The Maxima Discussion Links......
But to answer your question, is this for a 3rd, 4th, or 5th Gen????
Old Nov 9, 2002 | 04:20 PM
soopermax02's Avatar
Get a shop rag, or washclosh; and a small flathead screwdriver.
Put the shop rag up against finish and pop the front lamps out from the rear. Do the same to the rear ones, but they pop out from the side that faces the front of the car.
Study the clear corners and you will see what I mean, the stock ones are mechanically identical. Use the rag to keep from damaging the bumper finish.
You will need to buy lamps for the rear ones. I highly suggest using LEDs if you want them to be deep red. Regular bulbs are just pink and typically lose thier deepness over time.
Good luck, and welcome to the .org!
Old Nov 9, 2002 | 04:21 PM
wolf0's Avatar
5th generation
Old Nov 9, 2002 | 04:30 PM
PCGuRu2K's Avatar
Re: Side marker removal ?
Here's the write-up..
http://www.5thgenmaximas.com/clearinst.html
Old Nov 9, 2002 | 04:44 PM
Re: Re: Side marker removal ?
Which reminds me of one thing I forgot. Using the silicone is important. Over time the seals will break down and harden, after that they are virtually useless. Just putting a little silicone around them helps greatly and it's not a permanent bond; it's very easy to take off.
Old Nov 10, 2002 | 11:46 AM
PCGuRu2K's Avatar
Re: Re: Re: Side marker removal ?
Definitely use some clear silicone on allthe sidemarkers. Put it around the seal. This will prevent moisture. I've had my clears on now for over a yr with no moisture problems whatsoever..
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Colossus
Sep 9, 2015 05:46 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
