Bridgestone Potenza RE040 in 225/50/17
Old Nov 17, 2002 | 08:50 PM
ABS's Avatar
ABS
The Bridgestone NA web site shows that the RE040 is now available in the 225/50/17 size. Anyone know about these tires? Are they ok in the snow, the rain, or just dry weather. I also believe these may be the OEM tire for the 350Z front wheels. Any information is welcome.
Old Nov 17, 2002 | 09:58 PM
AgisAbatzoglou's Avatar
Re: Bridgestone Potenza RE040 in 225/50/17
Thay are used in the Z car.
Old Nov 18, 2002 | 06:23 AM
maxman00's Avatar
So they are used on the Z, do we know anything else?
Old Nov 18, 2002 | 06:48 AM
y2kse's Avatar
http://www.bridgestone-firestone.com...02/020731d.htm
Old Nov 18, 2002 | 07:06 AM
maxman00's Avatar
After doing a little research, I found that they do not have a lot of tread wear to them and that the overall performance was not up to par with others in the same catagory. From what I read, they are just blowtenzas. If you are spending around 170+ on a tire, you should go with the pilot sport a/s.
Old Nov 18, 2002 | 08:09 AM
Galo's Avatar
Maxima Pilot
While true that these dont appear to be
highly-rated tires, the fitting of this tire size to the Z-car will no doubt inspire several other tire manufacturers to support the 225/50/17 size, and that's good for the rest of us...
Old Sep 23, 2003 | 12:00 PM
2k2MaxiBlue's Avatar
i have had these tires for sometime now, compared to the re92, i notice better traction, they peelout slightly less, and stick to the road much better on sharp turns, i never had them in the winter, but i doubt there will be much difference. 17" wheels are not that good for the winter anyhow.
Old Sep 23, 2003 | 01:30 PM
koostermax's Avatar
i've seen them...
up close on the 350Z, Mazda RX8, and the IS300...
Treadwear rating was slightly better than blowtenza re92s but tread pattern way more agressive and appeared to be way more stickier... ride noise and comfort will be compromised as several reviews of these cars did mention substantial noise and roughness...
I'd think the re 730's will fare much better than the 040's...
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
Maxboy23
Sep 8, 2015 06:53 PM
2ndMAX
Jul 11, 2001 09:59 AM
JUGSMAX
Apr 20, 2001 10:37 PM
ru4real
Mar 12, 2001 08:59 PM
