2002 Tail light Installation on 2000 Model
Old Nov 28, 2002 | 01:28 PM
RudeNGrimey11's Avatar
Hey does anyone know if you can just directly replace the stock tailights for a 2000 with the 2002 tail lights. Are the harnesses the same? Is it as easy as dismount stock, unplug, plug in new light, remount. Or are there any complications that I should know about b4 trying.
Old Nov 28, 2002 | 01:59 PM
Y2KSESteve's Avatar
It is a direct replacement. There are 4, 8mm screws I believe that you can get out with a deep socket. THere is also a clip that needs to be undone. Push out the light from the inside after the screws are out. Its really pretty simple.
Old Nov 28, 2002 | 02:05 PM
MichaelAE's Avatar
Re: 2002 Tail light Installation on 2000 Model
Good 2K2 Tail Installation Write-Up
It is a piece of cake to do.
Old Nov 28, 2002 | 03:22 PM
TimW's Avatar
The silent but deadly Moderator
well, its SUPER easy.. but the sealant is pure evil. if it werent for the nasty sealant, you could do both sides in 5 mins tops... If you plan on cleaning the sealant off, dont wear anything you like.. and have some mineral spirits close by.
Old Nov 28, 2002 | 04:56 PM
BigDogJonx's Avatar
Yeap that sealant is pure evil. When I pulled the light off the car, i had it about 6"s away from the car and there was still a solid crap of sealant between the tail light and the frame of the car.
Dixit
Old Nov 28, 2002 | 04:57 PM
Wasim521's Avatar
don't clean off the old sealant
Actually, I found it better not to clean off the old sealant - It's good to help hold the new lights in. I've had my tails on for a while now and no problems, so there's no need to clean it off.
Old Nov 28, 2002 | 06:22 PM
TimW's Avatar
Re: don't clean off the old sealant
yeah, I ended up cleaning some just by scraping it and only made one pass around the new lights instead of the recommended 2x.
vingodine
45
May 21, 2016 12:46 PM
220k+ A32
Aug 17, 2015 03:57 PM
Nintensity
Aug 13, 2015 05:41 PM
fastcarny
Aug 12, 2015 03:50 PM
yat70458
Aug 3, 2015 01:16 PM
