Starting Noise
Old Dec 2, 2002 | 12:09 PM
mikemike's Avatar
Starting Noise
I get a Whoosh! sound coming from the driver side engine close to the firewall during recent cold starts. Could it be the starter? Any idea what types of re-occurring problems may be causing this sound? It turns over just fine, but the noise is very loud and unusual. Also, I am coming up on the end of my warranty. I have had the rotors replaced,the trans sensor and shift sensors all replaced under warranty. I am having the car brought in for a good once over and 30K service and have a good relationship with the service manager (beleive it or not). Any suggestions on what TSB's might be worth a once over? I am not having any strut noise and do not ordinarily look for problems, but the warrenty is almost up and one can't be too careful.
Old Dec 4, 2002 | 10:20 AM
Eenis's Avatar
Ditto
Mike, i'm in the same boat. Mine starts fine, shoots up to 2k rpm's (or however high it goes), but makes that crazy noise. I have 48k miles and yup, it only does it on cold starts. lemme know what you find out.
Old Jan 22, 2003 | 06:48 AM
jconte's Avatar
Either of you guys find anything out about this? I have about 51K on my 2000 SE and it does the same exact thing. I read that relubing the starter gets rid of the problem. And obviuosly replacing it will do the same thing. Replacement is expensive, but I wold think it is laboorious to remove, relube and re-install as well.
Let me know if you find a resolution.
Old Jan 22, 2003 | 07:14 AM
tkarrh's Avatar
I have the same problem with my 2K SE. I think it could be belts.
Old Jan 22, 2003 | 07:40 AM
vito1281's Avatar
I believe there was a thread on this not too long ago, but it was mostly 02/03 owners with the same problem--starting noise when starting in cold weather. The final consensus was that it's the belts, and as long as the car turns over fine, you shouldn't worry about it.
Old Jan 22, 2003 | 07:41 AM
Galo's Avatar
Maxima Pilot
'Whoosh' sound or the rather normal
timing chain rattle that lasts for maybe a half-second or so? If it's the latter...all VQs do that ocassionally..the timing chain 'whiplashes' a bit until the tensioners get 'pumped up' with oil pressure.
Heck, my '97 did that ocassionally, my '01 ditto. Look at it as the price u pay for having 'forever lasting' chains instead of belts.
Old Jan 22, 2003 | 07:55 AM
Zog's Avatar
Zog
I started getting timing chain rattle when it started to get cold here. Now that it's full fledged cold here, it still happens, but not all the time.
My problem is every now and then it will rattle for like 5-10 seconds. Of course i can't reproduce it for my dealer. But it kinda annoys me.
Old Jan 22, 2003 | 08:08 AM
Galo's Avatar
Maxima Pilot
Wow...five-ten seconds is WAY too much...
what kind of oil/oil filter R U using?
Old Jan 22, 2003 | 08:54 AM
Zog's Avatar
Zog
Re: Wow...five-ten seconds is WAY too much...
Standard nissan stuff. I get my oil changed @ my dealer for 19.99. I've even tried letting my car sit at the dealer for 4-5 hours, but i simply cannot reproduce it for them.
Old Jan 22, 2003 | 09:03 AM
Ma><iManiac's Avatar
Re: Re: Wow...five-ten seconds is WAY too much...
I'm in Atlanta, and this morning it was really cold outside (30s) and i noticed a slight metalic grinding type sound when i started her (2K2 SE) up. It lasted for just a fraction of a second. Is that what you guys are talking about? It only does it on a cold start like from sitting overnight.
Old Jan 22, 2003 | 09:07 AM
Galo's Avatar
Maxima Pilot
daaaas it! Zoog, dunno what to say...
Old Jan 22, 2003 | 09:48 AM
TimW's Avatar
The silent but deadly Moderator
I dunno.. but mine made this "woooonk!" noise last weekend.. it almost sounded like a horn. and there was a buzzer like feel too, definate high frequency vibration. My wife was like 'what was that?' I told her that was my new Lexus calling.. :/ unfortunately, that is some time off.
Gawd, I hope its the damn starter. it sounded like a spun a main bearing.. I was glad to hear that whoosh sound after that..
Old Jan 22, 2003 | 09:50 AM
Galo's Avatar
Maxima Pilot
Tim...check your PMs...take a look at it and
my last post to the Nissan serious service problems' thread...
galo
Old Jan 22, 2003 | 09:58 AM
TimW's Avatar
sh..., check yours!
Old Jan 22, 2003 | 02:57 PM
Gumoj's Avatar
So What are we going to do about this?
So guys,
What are we going to do about this problem? We cant reporduce the problem at dealer's lot unless u live at the dealership!!
Old Jan 22, 2003 | 03:19 PM
Maximax2's Avatar
Re: 'Whoosh' sound or the rather normal
ahhh - been wondering what that was. thanks!
Old Jan 23, 2003 | 06:05 AM
Zog's Avatar
Zog
There's really nothing you can do about it. *IF* you were able to somehow reproduce it for your dealer, they would most likely tell you it was normal. From what i've heard, it is a normal occurrence. So we'll just bring this thread back up every winter.
Old Jan 23, 2003 | 06:57 AM
SoloMaxima
my 2k1 makes the same sound when i start it...the sound last for about 1sec or less....it never did this until recently because it has been freezing cold this week in nyc...20 and below...
Old Jan 23, 2003 | 07:02 AM
TimW's Avatar
yeah, I've dealt with this kind of thing before with them. They will want to keep the car.
Me: There's a problem starting in the morning when cold.
SM: Well, if you cant reproduce it warm, just leave it with us
next day...
me: so what did you guys find out.
SM: everything checked out.
me: what time did you start it?
SM: we were busy, we just started it a few mins ago
me: rrrrrrright, its noon... and about 50 degrees now.. tell me again why I needed to leave it?
SM: well, we'll keep it till tomorrow and try again.. but you'll need to bring the rental back today...
me: rrrrrrrright... forget it.
Old Jan 23, 2003 | 09:51 AM
ahheath's Avatar
staring noise/problem
My 2000 SE (almost 50k miles) has been having a similar high pitched noise and rev up to 2xRPM, but mine is now at the mechanics because my car would rev up, but quickly rev down and stall out (even as I'm driving). They think it is a problem with the engine controller/computer. Anyone have a similar problem?? I love my car, but not when it acts up.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
trungg86
Sep 4, 2015 04:58 AM
