Changed oil and installed Hella horns today....
Old Dec 14, 2002 | 12:08 PM
Bluesbrekr's Avatar
Doctorate in Detailing
Just did an oil change on my 2K2. I used to change my own oil all the time, but have taken my previous cars to a Valvoline quick change garagefor the past 15 years. Since visiting the org, I decided to get back to doing it myself. Got an OEM filter and Castrol GTX.
Then I installed the Hella Supertone horns I just got from the GD. I looked all over to find as much info on the install as I could. My auto electrical skills are fair at best, and I was hoping to avoid using the relay. I removed the stock horns, attached the existing wire to the Hella's silver connector, and ran a ground from the copper one. (a thread on an MR2 site said the silver was the positive connection) Oh yeah, I disconnected the battery before I started..that much I know!!
Even without the relay, these sum britches are pretty loud!!
Scared the crap outta my wife when she came home from the store!!
Hopefully, I won't blow any fuses...I usually don't hold the horn on for more than a second or so. But I kept the relay, just in case...anybody else from the GD got them installed?
Old Dec 14, 2002 | 05:41 PM
Vadim's Avatar
Re: Changed oil and installed Hella horns today....
I also got them installed about 4 days ago. i didn't know that silver is the positive, thanks for the info. i will go and check my connections.
Old Dec 14, 2002 | 11:31 PM
Triple8Sol's Avatar
I miss the .org!
I got the Hella horns installed today too! Didn't use the relay either. I actually wired it with the copper plug as the Positive, and ran a ground fro the silver plug. Does it really matter which way you do it? It seems to work just fine?
Old Dec 15, 2002 | 04:06 AM
Bluesbrekr's Avatar
I was thinking about that too. I am going to swith the leads and see if it makes any difference. Maybe the + and - info wasn't accurate or important.
I'm now thinking about adding the relay, to see how loud they can REALLY go.....
Old Dec 15, 2002 | 09:25 AM
PoLo's Avatar
2-Wheelin it...
- doesn't matter which connection you use
- if you hold the horn for more than a few seconds, the fuse will blow. relay is htere to provide the power it needs. for 2k2's, in front of hte battery there is a fuxe box with 2 available slots. i placed my relay there...clean, hidden, and loud.
Old Dec 15, 2002 | 09:40 AM
Bluesbrekr's Avatar
Thanks for the info on the fusebox, PoLo. Sounds like the ideal spot for the relay! I'll check it out.
Old Dec 15, 2002 | 10:46 AM
PoLo's Avatar
2-Wheelin it...
RELAY IS ON THE TOP RIGHT (THE BLACK ONE)
STOCK TO HELLA COMPARISON
MOUNTED
Old Dec 15, 2002 | 11:21 AM
Bluesbrekr's Avatar
Great pic
thanks for posting the pic, PoLo. Looks like a good fit for the relay. That's where I'll put it!
Old Jun 10, 2003 | 08:01 PM
00MaxSE's Avatar
Pointy Elbows
Write up?
Anybody have the write up for the install?
J.
Old Jun 10, 2003 | 09:27 PM
Triple8Sol's Avatar
I miss the .org!
I've had my Hellas in for awhile w/o the relay. I've held it down for a long time, and it has not blown.
Old Jun 11, 2003 | 06:40 AM
Bluesbrekr's Avatar
Re: Write up?
J.
I just used the instructions that came with the horns. Also check out this link....
http://www.susquehanna.com/susq/other/horns.htm
Hope this helps.
Cotozic
Jun 28, 2017 08:01 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
tnewbs
Aug 28, 2015 10:15 AM
Maxgig
Aug 18, 2015 09:17 PM
RealityCheck
Aug 5, 2015 06:18 AM
