What is the latest and greatest sparkplugs to get now?
Old Dec 17, 2002 | 11:22 AM
Maximam's Avatar
Old Dec 17, 2002 | 02:33 PM
92 SE-R 02 SE
i would always stick with NGK plat. plugs. they are the best...
Old Dec 17, 2002 | 05:27 PM
Maximam's Avatar
Does everyone agree?
Old Dec 17, 2002 | 05:32 PM
nismotech's Avatar
Yes, NGK is very good spark plugs.
The only other spark plug I had experience with is Bosch platium (4 claw)..didn't think it was any better tahn NGK.
Old Dec 17, 2002 | 08:30 PM
Virus's Avatar
NGK
Old Dec 17, 2002 | 08:35 PM
Triple8Sol's Avatar
I miss the .org!
What about Denso Iridium plugs?
Old Dec 17, 2002 | 08:36 PM
hiphop4321's Avatar
What about Denso Iridium spark plugs?
Old Dec 17, 2002 | 09:41 PM
emax02's Avatar
People seem to think copper plugs perform better. There real cheap so I am going to try switching to them once my car is repaired(MAF fouled my plugs).
Old Dec 17, 2002 | 09:45 PM
Maximam's Avatar
I know in the LS1s we take out the stock platinum plugs as fast as possible and replace them with copper NGKs. I am not entirely sold on platinum plugs. What do you think NGK coppers?
Oh by the way how big of a job is it on the Maxima?
Old Dec 17, 2002 | 09:46 PM
emax02's Avatar
Look up one post
Old Dec 17, 2002 | 09:52 PM
Maximam's Avatar
Originally posted by emax95
Look up one post
OK I did question answered.
How about my second question?
By the way I was just drooling on your website when you just replied. VERY nice Max!
Old Dec 17, 2002 | 10:01 PM
emax02's Avatar
Question #2. That depends on how mechanicly inclined you are. The front 3 plugs are real easy to swap. The rear 3 are another story. At the very least the intake manifold runner needs to be removed. In all honesty it's easier to just remove the whole intake manifold. I expect it to take me about 45 minutes to do the plugs.
Old Dec 17, 2002 | 10:25 PM
Maximam's Avatar
Will a new gasket be needed?
Old Dec 18, 2002 | 03:02 AM
leungjc78's Avatar
Iridium?
Copper is suppose to be better because it has less resistance (electricity can flow thru it better.) Platinum have more resistance but it last much longer, so it is the spark plug of choice for cars.....
Iridium is suppose to be less resistance than copper AND tougher than platinum.
So the best of both worlds?
Comments??
Old Dec 18, 2002 | 04:50 AM
UMD_MaxSE's Avatar
Got Bent?
Copper plugs should perform better, but they will need to be replaced sooner... like after 30k miles
Old Dec 18, 2002 | 05:55 AM
victor's Avatar
emax,
how do you know that the the plugs are bad due to the MAF?? my MAF went out on me a month or so ago, and i had it replaced with the newer MAF. i want to know if i have to replace mine also, without having to pull them out for inspection.
Old Dec 19, 2002 | 09:18 AM
optimus1's Avatar
Re: What is the latest and greatest sparkplugs to get now?
Fifty million years ago, an asteroid composed almost entirely of the precious metal Iridium (Ir-77) struck the earth creating the Gulf of Mexico. From this catastrophe came a metal with properties ideal for spark plug construction. Using this element, DENSO has evolved spark plug design to a new level. Using Iridium, which is 6x harder & 8x stronger than platinum, the tip can be shrunk to only 0.4mm. This means the voltage requirements are decreased while firing performance is greatly improved.
.02
Old Dec 19, 2002 | 07:01 PM
emax02's Avatar
Originally posted by victor
emax,
A bad MAFS makes the car run very rich, so rich that it fouls the plugs.
Old Dec 19, 2002 | 08:25 PM
downby3's Avatar
Denso Iridum and Ngk are practically the same. I buy Denso because they give you a great comparison on the box against leading spark plugs. I would recommend denso iriduim and Viteck wires! Just my 2 cents
Old Dec 19, 2002 | 08:27 PM
downby3's Avatar
Re: Iridium?
Comments??
Actually iriduim performs better, its like 50 times hotter than copper. Its proven!!
Old Dec 20, 2002 | 06:30 AM
victor's Avatar
thanks man.
Old Dec 20, 2002 | 08:32 AM
T-bone's Avatar
From what I have read, both Platinuma and Iridum last a LONG time; Iridium lasts the longest. I also have read that Copper may be a good option for NON-N/A cars.
I went with platinum on my 2000 and I did not have much trouble. It just took a while to finish. Is the install on the 2K2+ different than on 2K and 2K1's ?
Old Dec 20, 2002 | 11:26 AM
Maximam's Avatar
Is the Iridium the plug to get then? Denso?
Old Dec 20, 2002 | 12:00 PM
Maksim2000's Avatar
Originally posted by downby3
Viteck wires!
For what ?
Old Dec 20, 2002 | 12:02 PM
T-bone's Avatar
If you get Iridiums, you MAY never have to change the plugs again. I have read estimates of them lasting up to 200K miles.
Old Dec 20, 2002 | 02:29 PM
downby3's Avatar
DENSO is the name brand of an iridium plug, just like NGK is the name brand of one too. I prefer DENSO though. In my opinon, that would be the plug to get.
Old Dec 20, 2002 | 03:11 PM
VMaximus02's Avatar
http://www.rvmracing.com is listing them for sale ($68.99/set) but I am not sure if the part number (IK16-5303) is correct since they listed them for both 2k-2k2? FYI, NGK has difference part number for 2k & 2k2 according to Courtesy Nissan website.
bumpypickle
Sep 20, 2015 08:22 AM
rhonster
Sep 19, 2015 04:29 PM
Blaxima
Aug 31, 2015 01:02 PM
Tha'-Max
Aug 30, 2015 01:14 AM
Maxinesdaddy
Aug 21, 2015 11:43 PM
