noise coming from coilovers..NEED HELP!!
Old Dec 19, 2002 | 06:08 PM
rob van dam's Avatar
i got my ground controls and tokicos on....i had it reinstalled today with all the rubber bushings put on....i mean we put so much rubber in there i have no lcue why the resr still makes noise......it makes clanking noises when i go over bumps...most of the time not all the time.....why is this?...what can be done??
Old Dec 19, 2002 | 06:10 PM
Greg's2kGLE's Avatar
Are your coils wrapped? They could be touching each other when they are compressed.
Old Dec 19, 2002 | 06:18 PM
no they are not...but when i press down on the car i dont hear the clanking noise.....but i guess a bump in the road applies more force to the car than me pressing down on it....ummmmm....does anybody else have a slotuion to this problem?...or does anybody else know what this could be?
albert
Old Dec 19, 2002 | 07:09 PM
gtr_rider's Avatar
192.168.1.1
albert
http://www.vqpower.com/v2/modules.ph...&pid=11:gotme:
Old Dec 19, 2002 | 07:12 PM
00Semaxi's Avatar
hate to say Albert but I told you so.
Old Dec 19, 2002 | 09:50 PM
well it isnt to to bad...the car looks great though
Old Dec 19, 2002 | 11:51 PM
ToYLeT902's Avatar
JET Speed Lab
tokico blue's arent meant to handle GC's
Old Dec 20, 2002 | 09:22 AM
SVTTODAMAX's Avatar
Did you shim them like I told you?
Old Dec 20, 2002 | 09:39 AM
jrflanman's Avatar
albert
Here is some basic stuff to check incase you just missed it.
Ok My friend had sort of the same problem. He had the springs switched around. One of the front was on the back and the spring compresed all the way because it wasnt made to handle all of the weight of the front. Check the Numbers on the springs. Make sure you have them in the right place. Also make sure u tighted the **** out of the top of the strut. If not it will make a knocking noise also.
I hope to put mine on this weekend. good luck
Old Dec 20, 2002 | 11:01 PM
the ride is fine.... ..i know from experience..it is working for me.....
Old Dec 21, 2002 | 08:12 AM
yep...and the noise is still there..
Old Dec 21, 2002 | 08:14 AM
WELL....my friend drove my car around and i was in the trunk listening for noise...and i saw the top strut go up and down and make clanking noise when we went over bumps.....so i found the problem..but how to fix it.....screw the bolt on tighter?..OR add more rubber cushing so that it will not move up and down?....please help me
Old Dec 21, 2002 | 02:30 PM
njmaxseltd's Avatar
Ground controls are noisey by design. Not to much you can do unless you get creative. Top and bottom of the springs should be seated on some kind of isolation to avoid metal to metal. But unfortunately that makes adjusting the height difficult.
The ground control spring is narrow, it's very possible that the rear Nissan OEM isolation sleves might fit perfectly on both the top and bottom coils. Might wanna give that a try if you have the sleve from your old rear springs.
Old Dec 22, 2002 | 03:02 PM
thanks....
isloation sleves?...is there supposed to be some rubber at the top of the rear struts?...does anyone know
pjgreek
Sep 9, 2015 09:30 PM
lux97Max
Sep 4, 2015 05:42 PM
jfl330
Sep 4, 2015 01:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
