2k2 6 speed problem (long)
Old Dec 26, 2002 | 02:39 PM
20 MAXIMA 02's Avatar
This morning, i decided to open up my car from a stop in a secluded area behind some factories. I wanted to see how fast i could do a 0-60 run with my friend holding the stopwatch.
Now, my car has 39,000 miles on it already and the clutch was replaced at 10k due to a "dying squirrel" squeaking.
I dropped the clutch at 3k rpm and the car took off, but the clutch never fully engaged, the pedal stuck to the floor and slowly released (even though my foot was completely off it). It was as if i was RIDING the clutch all the way through first gear up to 6400 rpm.
when i shifted into second gear, i actually had to wedge my foot under the clutch pedal and pull it off the floor.
my buddy thought i was riding the clutch too, because the rpm stayed at about 5,500 rpm for both first and second gears until the clutch finally engaged.
he timed a 6.24 second 0-60
I've had problems with the nissan clutch before, but this is completely new to me. under normal driving, the clutch has always engaged predictably. But during that run, its as if the clutch sticks and doesnt want to engage under hard acceleration.
any comments would be appreciated.
btw... i've driven stick since i got my permit, so its def. not because im a "new stick driver."
Old Dec 26, 2002 | 02:44 PM
swallac2
Sounds like it was low on fluid and or the car hadden't warmed up yet. My Grand Am did something similar to me once and it ended up that my slave cylinder had leaked all of the fluid.
Try checking the fluid, you may have a leak.
Old Dec 26, 2002 | 02:46 PM
what fluid?
Old Dec 26, 2002 | 03:12 PM
njmaxseltd's Avatar
Originally posted by 20 MAXIMA 02
what fluid?
Oh this is good....
Old Dec 26, 2002 | 03:15 PM
swallac2
what fluid?
There ought to be a fluid reservoir for the clutch. I've never looked on the Max, but there has been one for every other clutch vehicle I have owned.
Old Dec 26, 2002 | 03:48 PM
MaximaMan77's Avatar
Originally posted by njmaxseltd
Oh this is good....
ROFLMAO
Dude where do you go in the car, all over the U.S. 39k Thats 3k/mo. Your bumper to bumper is shot in 1yr. at least you still have the drive train warranty take it in and have it looked at.
Old Dec 26, 2002 | 07:14 PM
maximadave's Avatar
detailerdaveb@gmail.com
Oh this is good....
Old Dec 26, 2002 | 07:37 PM
Originally posted by maximaman777
ROFLMAO
gf lives in D.C. area, hafta keep her happy
Old Dec 26, 2002 | 08:42 PM
realtor's Avatar
what fluid?
There is a small reservoir right next to the brake fluid reservoir. That's where the clutch fluid (DOT 3 brake fluid)goes. Yes,they both use the same fluid.
Old Dec 26, 2002 | 11:15 PM
PeterUbers's Avatar
Is the clutch considered a wearable item? Is this covered under the 5/60K?
Old Dec 27, 2002 | 06:19 AM
spta97's Avatar
ROFLMAO
If your clutch was already replaced at 10,000 miles, you can claim that this is the original problem and they never fixed it properly. Just tell them that you were breaking it in for 29,000 miles to be sure
Old Dec 27, 2002 | 06:38 AM
ghostrider17's Avatar
Originally posted by maximadave
Old Dec 27, 2002 | 07:55 AM
Kojiro_FtT's Avatar
Holy crow. Is she really worth destroying a $25,000 car? Get a local GF for christ sake!
Old Dec 27, 2002 | 08:46 AM
Young04's Avatar
or get a cheaper car. 39K in one year...does she ever come to see you?
Old Dec 27, 2002 | 11:10 AM
itz $29,320 car
i had it appraised by the dealer and itz only worth $17,000 now
she was local until she went off to college
Old Dec 27, 2002 | 11:18 AM
ajahearn's Avatar
slave cylinder
I had this problem on my 89 and it was due to my slave cylinder going out. I don't know if the 6 speeds use a similar arrangement, but if it is the cause, have them replace both cylinders. Replaced the slave and then had to replace the master about 6 months later. Just to beat the question, mine went out after nearly 110K miles so it was normal wear and tear IMHO.
Old Dec 27, 2002 | 12:06 PM
Re: slave cylinder
for your problem, did your clutch engage normally under normal driving but stick to the floor under hard acceleration?
Old Dec 27, 2002 | 12:56 PM
ajahearn's Avatar
too long t remember
I just remember the clutch pedal going to the floor and having to force shifts. With your description it could still be the clutch cylinders as it is my understanding that they work off of vacuum pressure from the engine. Under hard acceleration the engine will not generate a lot of vacuum and it will typically shut down things (like AC) in favor of power.
The ESM for 02's says that for a spongy clutch (which was the closest thing to your description) should have the master cylinder, operating cylinder (which I was referring to as the slave), and the clutch lines checked for air.
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
jfl330
Sep 4, 2015 01:44 PM
