Oxygen sensors ... where to buy?
I've got a 2001 cali-spec Maxima and I am looking forward to installing my Stillen y-pipe and Custommaxima cat-replacement pipe.
It's got 27k miles. Can I reuse the O2 Sensors? I know it's a good idea to replace them around now, especially since I'll be doing the work.
If I need to replace them, I'm scared of how much all four will cost. Can anyone break down where to go to buy them and how much I'll have to spend?
Aaaahhhhh....thanks a ton, guys.
I always thought you were supposed to replace your o2 sensors every 30k miles...is that not the case normally with the 5th gen?
Lastly, when AM I supposed to replace the O2 sensors?
There's no real time when you have to replace them... if you get a code that indicates a faulty sensor you should replace it. Or if you have a lot of miles or notice a hit in performance, you can replace them. Even then, only the two upstream sensors monitor A/F ratio... the downstream sensors check for presence of the pre-cats/main cat.
Just go til you code.
