2003 grille on 2000?
Old Jan 2, 2003 | 11:15 PM
alamak's Avatar
hi all,
i'm new to this forum and the maxima..
have a 2000 Cefiro Excimo (Maxima) which i hope to replace its roundish grille to the one on the latest maxima..
like the one here.. http://www.cefiro.com.my
my question is.. can i simply buy an 03 grille and replace it on my 00, or are modifications required..
thanks in advance.
Old Jan 2, 2003 | 11:31 PM
KennyLau's Avatar
Re: 2003 grille on 2000?
I doubt this will work. From the look of the Cefiro from your link, it looks as though your grille is integrated to the hood. American Maximas have their grilles integrated with the front bumper cover. Also the general shape and design of that Cefiro's front-end compared with the Maxima is different.
Remember, the exterior of the Cefiro and the Infiniti I30/I35 is designed in Japan. The exterior of the Maxima is done in Southern California. Nissan does not care that exterior parts between the Cefiro/I30/I35 and the Maxima do not match and are not interchangable because they are all designed for different markets to better differentiate each one.
Old Jan 3, 2003 | 12:05 AM
alamak's Avatar
Re: Re: 2003 grille on 2000?
thanx kenny,
my current cefiro grille is integrated into the hood, like the 03 cefiro..
the grilles are about the same, except the mine are more roundish at the corners, not sharp and snazzy like the new one..
cheers!
Old Jan 3, 2003 | 02:28 AM
BigDogJonx's Avatar
Only reason I dont believe this will work is if you take the 2000 maxima and compare it to a 2003 maxima, the grille size actually got larger. It opening is 1" taller than the 2000. Also the 2003 grille can be removed from the front, the 2000 grille cannot, it is basically integrated into the front bumper, basically molded.
Dixit
Old Jan 3, 2003 | 09:42 AM
MaximaZero's Avatar
Needs non-Maxima Friends
Originally posted by alamak
hi all,
thanks in advance.
though the maxima grill would probably require a lot of custom work, i think this one should bolt right on to your car:
Old Jan 3, 2003 | 10:25 AM
K Pazzo 6's Avatar
get lenght & height sizes on both grills first
Old Jan 3, 2003 | 06:33 PM
alamak's Avatar
Thanx! MaximaZero..
That's the exact one on my 2000, except that the logo says "Cefiro" instead of Infiniti..
hmm.. the 03 grille does indeed look slightly larger than the 00 one..
looks like i have to drop the idea of DIY face-lifting the cefiro..
Mahmuth
Aug 16, 2024 08:23 PM
REDinLV
Aug 15, 2024 12:30 AM
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
ricky7780
Sep 24, 2015 06:50 PM
