Warped Rotors....??
Old Jan 9, 2003 | 09:52 PM
SoloMaxima
Warped Rotors....??
my rotors are warped...but sometimes when i brake, the steering wheel wont vibrate...everything seems normal...but than other times it vibrates like crazy when I brake...
does this happen to anyone else...
it vibrates most of the time when i brake..
Old Jan 9, 2003 | 10:17 PM
kpark's Avatar
Re: Warped Rotors....??
Yup, it happens to me also. Braking is smooth right after I get a car wash and all the brake dust and stuff gets washed out. After a few days it's back to brake jutter like crazy. Waiting until I need my next brake job to install Stillen rotors.
Old Jan 10, 2003 | 07:40 AM
Zog's Avatar
Zog
Yeah that's what happens. When mine started to warp they only vibrated during a certain window of speeds. It'll get worse as you go. Eventually mine vibrated almost any time i used the breaks over 20 mph.
Old Jan 10, 2003 | 08:05 AM
Igor911's Avatar
Sorry Bro, After seeing your sig i needed to do something to it LOL, looked very tempting
Old Jan 10, 2003 | 08:14 AM
Donkey®'s Avatar
wat
Are you positive they are warped? Do you have aftermarket rims?
Old Jan 10, 2003 | 08:19 AM
krazyd's Avatar
I need the TSB for my 2k1 Warped Rotors. I'm bringing in the car and want to have it incase they give me any problems.
Old Jan 10, 2003 | 08:25 AM
Igor911's Avatar
As long as your under the 36k miles, you dont need anything. Just come in and set your foot down and say "replace my rotors AND PADS!!! under the TSB for warped rotors"
Make sure you get some pads too! Whenever u replace rotors, u need a new set of pads so they wont warp again.
My friend GXE-r who lives close to me, recieved rotors and pads for free under 36k protection wntty.
Old Jan 10, 2003 | 08:38 AM
CCS2k1Max's Avatar
If the dealer gives you crap, just tell them to look up TSB NTB00-088a.
Old Jan 10, 2003 | 09:34 AM
simon tx's Avatar
they will cut them
SoloMaxima,
I just took my 2000 GLE in for this problem. I had it for a while, but finally got there at around 33K miles.
Read the TSB closely - all it does it tell the service people how to cut the rotors.
You're going to have to fight a little harder to get a replacement.
First words out of the Service Advisor's mouth were " no brake inspection is covered under warranty - this will be at least $69.95" - I told him just look at them and tell the technician there is a TSB - I had the copy, but never showed it.
They called me later and said it would be done under warranty. I asked about replacements - they said no way.
Unless you have a super, service friendly dealer - you can forget replacements (unless this is something you've been there for in the past).
Just my experience
Old Jan 10, 2003 | 09:43 AM
Igor911's Avatar
Re: they will cut them
Originally posted by simon tx
SoloMaxima,
Just my experience
Actually, Right now nissan has a special going on for FREE BRAKE CHECK! I just had mine done for free and im at 60k
Old Jan 10, 2003 | 11:40 AM
spta97's Avatar
Re: Re: they will cut them
I had warped rotors on my 2k3 (no TSB) with 2100 miles. They cut my rotors (all 4) and sent me on my way. I argued ahead of time to get new rotors and pads but both the dealer and NNA told me no. It pi^sses me off because now my rotors have already been cut once therefore taking life away from them.
Old Jan 10, 2003 | 11:44 AM
Igor911's Avatar
Re: Re: Re: they will cut them
Next time u feel the SLIGHTEST judder, take that SH!IYAT back
and demand NEW
Old Jan 10, 2003 | 12:07 PM
MaxSC's Avatar
HELP!!
I just took my car into service yesterday, it was currently 36579, i planned on an oil change and fix brake bulb, but he called me later and told me i had to have my brakes replaced and rotors resurfaced. is this the same issue as you people have mentioned?? if so am i covered under any warranty due to tsb? can i get reimbursed?
thanks in advance
Old Jan 10, 2003 | 12:11 PM
Igor911's Avatar
Re: HELP!!
thanks in advance
I hope u didnt pay for all that
Old Jan 10, 2003 | 12:39 PM
Thorzdad's Avatar
My dealer cut the rotors (fronts only...the rears never warped) the first time I took it in (12k miles) When i brought it back at 20k, they replaced the rotors. Both times were covered by warranty.
Two weeks ago, I took it back again with warped rotors. Unfortunately, at 50k miles, it wasn't covered. Dealer claimed they'd never had problems with Maxima brakes before. Uh huh...yeah.
Old Jan 10, 2003 | 12:45 PM
CCS2k1Max's Avatar
Re: Re: HELP!!
Save the receipts (credit card and statement, as you should w/ all records) and if a TSB comes out, demand reimbursement from NNA. Basically you're the guinea pig, er data, they are collecting...
Igor, he did pay for that, but that's iffy since he's over 36K.
Old Jan 10, 2003 | 12:48 PM
Igor911's Avatar
Re: Re: Re: HELP!!
Ohh my mistake sorry, i didnt notice the current miliage he had.
Old Jan 10, 2003 | 01:14 PM
MaxSC's Avatar
Re: Re: HELP!!
Actually yeah i did, heres what was done.
The brake pads, resurface rotors, replace fan belt (cracked), replace rear brake bulb, oil change, and usual fluids and odds and ends.
total: $420.95
Old Jan 10, 2003 | 01:24 PM
Dawgs AE's Avatar
Re: Re: Re: HELP!!
total: $420.95
Was this for all four rotors and pads? Seems like a lot if not.
Old Jan 10, 2003 | 01:35 PM
MaxSC's Avatar
Re: Re: Re: Re: HELP!!
No!!, just the f'in front!!!! . Thats outrageous right??
Old Jan 10, 2003 | 01:39 PM
Dawgs AE's Avatar
Re: Re: Re: Re: Re: HELP!!
Sounds a little steep to me. That is why once the warranty is out, the dealer will never see my car again.
Old Jan 10, 2003 | 03:38 PM
Triple8Sol's Avatar
I miss the .org!
I had this problem too, and of course was more noticeable at higher speeds. Dealer diagnosed it as warped rotors and resurfaced them at about 8500 miles.
Old Jan 10, 2003 | 05:09 PM
realtor's Avatar
Re: Re: Re: HELP!!
total: $420.95
What do you mean by cracked fan belt? Max's have an electric motor that turns the fan(s). I think the dealer is pulling your leg as they usually do.
Old Jan 10, 2003 | 09:23 PM
spta97's Avatar
Re: Re: Re: Re: they will cut them
and demand NEW
I plan to. That was my argument that it could happen out of warentee. The thing is that I started to feel the judder outside of my 1000 mile break in period. I was going easy on the brakes and under 60 (well, 70 ) so I didn't notice it although it was probably there from the start.
Luckilly, I have all my files in a big folder that I will keep until I sell the car.
Old Jan 11, 2003 | 12:41 PM
SoloMaxima
Re: Re: Warped Rotors....??
nice..
raffivegas
Aug 23, 2015 09:54 PM
RealityCheck
Aug 5, 2015 06:18 AM
MrBurner
Apr 4, 2001 07:38 AM
DFWmax
Mar 21, 2001 03:00 PM
SWEETSOUND2001
Mar 1, 2001 12:52 PM
