$120 to install a Y pipe
Old Jan 17, 2003 | 11:35 AM
fhaze_max's Avatar
...seems a little high to me. I didn't even ask about the B&M STS?
Old Jan 17, 2003 | 11:50 AM
XXXL Cracker's Avatar
Re: $120 to install a Y pipe
I do not know where you are getting this done. The price is indeed high as the Y pipe is plug and play.
Only hard part about it is breaking loose the bolts.
D
Old Jan 17, 2003 | 11:56 AM
T-bone's Avatar
I have not installed a Y-pipe, but I plan to do so soon. The install, from what I have heard, is time consuming, but it's not hard.
The same rule applies for the STS. It's a good idea to do both at the same time; however, with the proper tools you CAN install the STS without removing the cat.
I would recommend doing the install yourself with the help of a friend. It will probably take the better part of the afternoon to install both of these parts.
Old Jan 17, 2003 | 12:01 PM
fhaze_max's Avatar
Re: Re: $120 to install a Y pipe
D
Spartan Brake and Muffler in Springfield MA.
I explained that it shouldnt take more than an hour with Airtools and a Lift. If I prep the shifter, they should be able to slap it right in there too. The car only has 40k on it, so I doubt the bolts are THAT bad. If it weren't for the cold streak here in the NE I get my fat a$$ on the ground and do it myself
Old Jan 17, 2003 | 12:10 PM
maxman00's Avatar
Re: Re: Re: $120 to install a Y pipe
That price is silly considering what they have to do. On a lift installing a ypipe would be a sinch. As others say it is simply pug-and-play.
BTW, if the studs going into the cat are the originals, then they will be tough to get off. However at a exhaust shop, they can heat them up and they should come right off.
Old Jan 17, 2003 | 01:00 PM
Y2KSESteve's Avatar
I got mine installed for 60, so id say 120 is pretty high.
Old Jan 17, 2003 | 01:11 PM
fhaze_max's Avatar
Im hoping that when they see it, and realize its pretty easy, they will drop the price.
Old Jan 17, 2003 | 02:39 PM
MNMax's Avatar
How bout this? Ask them their hourly rate, bring your y-pipe, then sit there and watch them do it, and pay them accordingly. See if they'll go for that one
Old Jan 17, 2003 | 08:46 PM
zeitgeist57's Avatar
I'm also needing to have a y-pipe installed, and was wondering if the prices people quoted included the necessary gaskets. I don;t have any gaskets (bought my y-pipe used) and I'm looking as to what seals/gaskets I need and where to get them.
Old Jan 17, 2003 | 10:24 PM
2kGLE's Avatar
120 is waayyy too high. i got mine installed for $40. Its pretty simple; if i had air tools or if it would have cost more to install i would have done it myself. find another place or demand their hourly rate and watch them like MN Max said; it sould take less than an hour unless they are retarded or trying to rape you.
btw zeitgeist57, you can get OEM gaskets at any nissan parts department; they will work with an aftermarket y. Make sure they are the right ones though. Budget and Nissan both gave me wrong parts.
Old Jan 18, 2003 | 12:34 AM
clipse's Avatar
$120.00??? I suggest you save that $120.00 and do the Y-Pipe install yourself. If you ever installed a header or cat-back exhaust before then you can do a Y-Pipe. If not, a Maxima ESM is your best friend.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Samedi
Sep 3, 2015 01:07 PM
