AC/Blower Motor Fix
Old Jan 22, 2003 | 06:35 AM
Compton's Avatar
AC/Blower Motor Fix
Problem:
Very annoying and loud Ticking/humming/noise coming from underneath or near the glove box area.
After reading about the TSB on this site, I went to the local Nissan dealer and bought:
Fix:
27220-2y910=Blower Motor for $58.50 (Old part#=27220-2y900)
27227-0e002=Blower Motor Cover for $10.68
I removed my glove box in 5 minutes and then replaced the blower motor and mounted the cover on the motor in another 5 minutes. I also cleaned a couple of leaves out. (There is a direct path from the engine compartment to the blower motor and that's how leaves get in.. I could see the hood once I removed the motor)
I am glad to say that the noise is totally gone.. It was the best $70 I ever spent cause that annoyed me to no end..
HTH,
Compton
Old Jan 22, 2003 | 05:32 PM
Y2KMaxGXE-R's Avatar
I had the same problem, and the dealership made it look like my fault. All they did is cleaned out the leaves, but told me they're charging Nissan as if they changed the blower motor, and wanted me to rate them 'excellent' on the survey.
If there is a TSB then why did you spend you own money on this??
Old Jan 22, 2003 | 06:15 PM
kramerica72's Avatar
A TSB is not a warranty or a recall. It just shows the techs how to correct a known problem. The only way the dealer will usually pay for something is if you are in warranty, or they really, really like you.
Old Jan 23, 2003 | 06:26 AM
Compton's Avatar
AC
My car is out of warranty and to be honest, I would rather pay $70 and do it myself than inconvenience myself for a day and give my car up and have to hassle with Nissan Service
Old Jan 23, 2003 | 07:06 AM
TimW's Avatar
The silent but deadly Moderator
I'm ready for my third motor.. and our pathfinder with the same motor is also ticking AGAIN.. Its the motor design. that new $58 (cheaper than the old one) is supposed to be better I think. I need to just buy one. (I already have the cover from the TSB and previous motor replacement)
Very annoying indeed.. Last time, they really scuffed up my glovebox. I'm the only one that can see it, but it made me mad as hell.. Just sloppy work.. I definately will be buying this one and doing it myself. not with the hassle at the dealer.
Old Jan 23, 2003 | 07:26 AM
Compton's Avatar
Its very easy to do.
Old Jan 23, 2003 | 08:02 AM
TimW's Avatar
I know.. thats what made it so hard to understand why they need the car for a day and messed up the glove box. :/ I took it out and saw it had spun the grease out. And that the motor wasnt servicable. At the time the motor was $100 and I was under the 36K warranty. So, I thought it would be better to get them to do it for free... well, nothing *free* I guess. 3 visits and some scratches later
Now that I'm in the extended warranty and I have a $50 deductible, I'll just buy the new motor and save myself hours by doing it myself.
Old Jan 23, 2003 | 09:27 AM
scmaxima2k's Avatar
hmmm...i gotta do mine too. I got approved for it to be done under warranty last march but i never went back to have them do it for some reason... So this is an easy job? Hmm sounds like a good job to do over spring break...thanks for the info.
-Steve
Old Jan 23, 2003 | 09:32 AM
Compton's Avatar
Steve,
I am certainly no mechanic, and it only took me 15 minutes total to remove glove box, remove and replace motor, install cover, and put glove box back on.. Very easy to do
Old Jan 23, 2003 | 09:45 AM
TimW's Avatar
agreed its as easy as doing the in-cabin air filter.. in fact, that would be a good place to start on instructions to at least get the glove box out if your a noob to the procedure. just go to courtesyparts.com and look at the instructions there.
If you have a sloppy dealer, by all means, this is easy enough to forgo all that headache.
Old Mar 2, 2003 | 02:33 PM
valkat's Avatar
Re: AC/Blower Motor Fix
Where did you find such inexpensive blower motor???
Originally posted by Compton
Problem:
Fix:
HTH,
Compton
Old Mar 2, 2003 | 04:28 PM
TimW's Avatar
call Dave Burnett, his info is in the sticky thread at the top of the forum.
Old Mar 2, 2003 | 10:26 PM
Compton's Avatar
BLower Motor
I called 2 dealers in Birmingham Alabama and was quoted the same price.
Old Mar 3, 2003 | 09:30 AM
valkat's Avatar
Actually, I called my local dealer and got the same price.
Thanks TimW and Compton!
Old Mar 12, 2003 | 02:16 PM
valkat's Avatar
Bad luck
I went to local dealer and purchased a new blower motor....the new, modified one! and replaced the ticking one....
Now what? it makes even more noise at high speeds!
dealer refused to take it back or exchange
HELP!!!!!!!?
Old Mar 12, 2003 | 06:09 PM
bigmaxx
Where did you find the instructions at courtesyparts.com? I did a few searches there and I couldn't find the instructions you are talking about.
Thanks.
Floktndr
Nov 30, 2015 07:48 PM
pears
Sep 18, 2015 05:25 AM
Vequity
Sep 10, 2015 05:26 AM
slowlifer
Sep 8, 2015 05:53 AM
