Is 10W-30 ok?
Old Feb 1, 2003 | 02:54 PM
Mystic_Lover's Avatar
Is 10W-30 ok?
I am an idiot. I accidentally used the wrong box that we have in the garage that has the Mobile1 10W-30 oil instead of the 5W-30. The car is full now and is ready to drive but I am wondering if it's better to flush the oil and use the 5W-30 or just leave the 10W-30 and drive it as it is.
Old Feb 1, 2003 | 03:06 PM
Green 2kSE's Avatar
It's absolutely fine to keep the M1 10W30 in it, don't worry about it.
foodmanry's Avatar
Da Roller Coaster!
Re: Is 10W-30 ok?
Synthetic or conventional? Either way I'm sure it will be ok. Just may have some dry starts if its conventional and the weather is really cold.
Old Feb 1, 2003 | 03:07 PM
C430's Avatar
If you live in a VERY cold (sub-zero) climate area, you may want to stick with the 5w-30. If you don't, 10w-30 won't hurt a bit.
I use 10w-30 or 10w-40 with no problems at all in northwestern New Jersey.
If you are still in doubt, check with your owner's manual.
Old Feb 1, 2003 | 03:14 PM
It is synthetic. I use only that. I live in Chicago and we've only had a few days of sub-zero windchill (not the temp itself). As far as the manual goes it says 5W-30. But I guess I'll just have to do with it.
By the way how often do you guys change the oil.
Old Feb 1, 2003 | 04:10 PM
iwannabmw's Avatar
Since it's M1, you won't really notice a difference between the 5W-30 and 10W-30. If it were a conventional, I would have drained it.
Old Feb 1, 2003 | 04:16 PM
PCGuRu2K's Avatar
I use Synthetic Mobile 1 10w-30 on mines.. Change it about every 3500K.. You'r fine using what you have there..
Old Feb 1, 2003 | 04:17 PM
PHATMAN5050's Avatar
I go for my oil change roughly when it says on the sticker on my windshield. About every 3,000miles or so.
Old Feb 2, 2003 | 10:52 AM
foodmanry's Avatar
Da Roller Coaster!
For synthetic you don't need to go as often. Just a waste of money.
talkinghorse
Mar 8, 2017 06:42 AM
steven88
Fluids and Lubricants
60
Feb 9, 2005 10:53 AM
matty
Dec 4, 2003 05:46 PM
DJLAX152
Aug 9, 2003 10:26 PM
IceY2K1
Jun 4, 2002 06:44 AM
