Had Custom Exhausts Put in!
Old Feb 3, 2003 | 10:10 PM
02MaximaSE's Avatar
Had Custom Exhaust Put in!
I just got a custom exhaust done....2.25 inches in diameter, I had these replaced.....
Factory B-Pipe Removed
Factory Crushed Pipe to Resonator Removed
Factory Resonator Removed
Custom 2.25 id piping from cat back adapted to factory muffler.
Sounds great, sorta like a very very low mumble, like a G35 sounds at idle, cant really hear much difference cause of stock muffler.
Butt Dyno tells me my 4500-6500 range has improved (dont feel like its struggling as much).
Low end remains the same.
Can anybody shed some light on what i may have gained or lost?
Should I get an aftermarket intake? if so which?
Old Feb 3, 2003 | 10:20 PM
Y2KSESteve's Avatar
Not a whole lot you could've really lost. The B-pipes are very constrictive. For intake I'd say Frankencar, but search will help you out a lot on that one.
Old Feb 4, 2003 | 09:39 PM
02MaximaSE's Avatar
Pics and Vids....
Factory Resonator
Horrible Factory Crush:
Videos:
http://www.thaiamrestaurant.com/exhaust/exterior.avi
http://www.thaiamrestaurant.com/exhaust/interior.avi
02MaximaSE's Avatar
Pics and Vids....
Old Feb 4, 2003 | 09:58 PM
KLOOGY's Avatar
L33t BMW Drivah
argh.. I hate to know that is what I have underneath... time for a b pipe and Y pipe....
Old Feb 4, 2003 | 10:21 PM
guchi's Avatar
Good Job on the videos and pics.
Really helpful to know what it would sound and look like.
laterz
Old Feb 4, 2003 | 11:24 PM
anskyruben's Avatar
Yankees pwn you !
Re: Had Custom Exhausts Put in!
How much did you end up paying for the work??
Old Feb 4, 2003 | 11:36 PM
clipse's Avatar
Re: Re: Had Custom Exhausts Put in!
Can you show some detailed pics from underneath to see what it looks like now???
Old Feb 5, 2003 | 12:01 AM
8702's Avatar
For a N/A 2k2, would 2.5" piping be too big?
Old Feb 5, 2003 | 06:29 AM
02MaximaSE's Avatar
Re: Re: Re: Had Custom Exhausts Put in!
I didnt want to pay for mandrel, and the performance shop guy said i didnt really need mandrel and 2.5 inches until i start S/C and more engine work, and that 2.25 is enough and shoe bending style isnt all that bad only a minute part of the pipe (he cut up mandrel bent and crush bent style pipe so i could see) and that anything vs. the stock piping is better.
I paid $100 installed for piping and all... and tipped him $20 since getting the 2.25 into the stock muffler and making custom mounts were a ***** to do and he made sure nothing rattled.
Old Feb 5, 2003 | 06:31 AM
02MaximaSE's Avatar
muffler pipe inlet vs. new pipe inlet.
Old Feb 5, 2003 | 08:54 AM
clipse's Avatar
Thanks for the visuals. So basically your running a 2.25 pipe after the cat all the way to the stock muffler??? No more resonator???
Old Feb 5, 2003 | 10:50 AM
Tripower's Avatar
2.5" exhaust on a Maxima may be overkill. I have a 450-500 HP V-8 that will run a 3" x-pipe reduced to 2.5" going into the mufflers and 2.5 going out the rear. Everything I read says that in that combo, 2.5 is enough. Too large of an exhaust can hurt performance by reducing too much back pressure.
Old Feb 5, 2003 | 10:59 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
I know it's off Topic...
I noticed in you sig that you have a goat! I just recently sold mine ('68 Ram Air 2 setup) to someone in Caliafornia. I loved that car, but the '65 is the one I really want. Mine wasn't stock either
On the custom Max exhaust...let us know if you decide to dyno and such. I'd be interested to see what you get out of that setup (especially for the money).
Old Feb 5, 2003 | 11:31 AM
2kSeattleMax's Avatar
There is a common misconception about backpressure. In actuality, its the selection of a pipe which gives the highest exit velocity for the gases. Its the velocity in a normally aspirated engine that has to be maintained. This can be overcome by superchargers and turbos.....which can benifit from a larger exaust.
Old Feb 5, 2003 | 02:24 PM
Tripower's Avatar
If I recall, backpressure plays a part in the scavenging effect of exhaust gases. If youe reduce the backpressure too much, you reduce the scavenging and reduce the potential power output. There's a bunch of stuff written about this on the web as well as tests where they show that too much backpressure can reduce an engines power output.
Old Feb 5, 2003 | 03:20 PM
Tripower's Avatar
I guess you get the meaning of my screen name then. I have a 440 (455 block, 428 crank) waiting to get dynoed in the next month to drop into the goat. Should be interesting! We'll be running trips on it initially. I hope I don't scatter the rear end too quickly! (stock 10.2") Nice to see a fellow org member who appreciates old Ponchos.
lowpost99
Oct 26, 2025 06:53 PM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
iflexsteel
Sep 2, 2015 08:04 AM
A32goldylocks
Sep 2, 2015 06:39 AM
