what EXACTLY does a UDP do?
Old Feb 10, 2003 | 07:11 AM
skandalouz's Avatar
does it just reduce weight? or does it actually give some HP too? if so, how much? (weight reduction and/or hp?)
Old Feb 10, 2003 | 07:15 AM
vito1281's Avatar
Re: what EXACTLY does a UDP do?
Don't have one, but I'll tell you what I know about it. It basically increases HP because it replaces a heavier OEM pulley. It doesn't add any power on its own, per say, but it makes the car quicker (I would imagine VERY slightly) by making the car a LITTLE lighter.
Old Feb 10, 2003 | 07:18 AM
jjs's Avatar
jjs
Re: Re: what EXACTLY does a UDP do?
Not quite right. It does not 'increase' HP...it simply frees up some of what the engine is producing but losing to accessories. The weight difference is to allow for more efficient transfer of the crank "turning energy" than for any overall vehicle weight savings.
Old Feb 10, 2003 | 07:22 AM
vito1281's Avatar
Re: Re: Re: what EXACTLY does a UDP do?
That's what I meant. That's why I said "per say" I guess you used the better expression "frees up ALREADY existing HP".
Old Feb 10, 2003 | 07:24 AM
jjs's Avatar
jjs
Re: Re: Re: Re: what EXACTLY does a UDP do?
gotcha
Old Feb 10, 2003 | 07:29 AM
skandalouz's Avatar
Re: Re: Re: Re: Re: what EXACTLY does a UDP do?
gotcha
how much does it "free up"?
Old Feb 10, 2003 | 07:37 AM
jjs's Avatar
jjs
Re: Re: Re: Re: Re: Re: what EXACTLY does a UDP do?
not sure...search on 'UDP and INCREASE' or something like that...should be some stuff out there
Old Feb 10, 2003 | 07:43 AM
vito1281's Avatar
From what I've read on here, I think it only frees up a couple or so, not much though.
Old Feb 10, 2003 | 07:48 AM
2002Maxxxima's Avatar
By 'freeing' up I think they mean it is a smaller pulley than stock. That being the case, it is easier for the engine to turn a smaller pulley because of leverage. This makes your accessories (alternator) run a little slower than normal. People that replace all the pulleys usually do it for looks to get them all to match. I think.
Old Feb 10, 2003 | 08:08 AM
Anachronism's Avatar
It is the same effect as lighter wheels or a lightened flywheel. Anything the rotatates takes energy to accelerate and a lighter object takes less energy. Supposedly a UDP frees up about 5 WHP.
A UDP also frees up some power by underdriving the accesories, so less power is use to turn the power steering/alternator and AC but most of the gains come from less weight. Theres a pretty good explanation on the custommaxima site -- http://www.custommaxima.com/UnorthodoxPulley.php
Old Feb 10, 2003 | 08:44 AM
asu174's Avatar
Clay Aiken has fancy genitals
Rotational mass is reduced, making it much more efficient. It's kinda the same theory as putting lighter wheels on your car. Less weight to turn= more efficiency......but not necessarily pure hp.
Dave B
May 29, 2001 11:07 AM
y2kse
Feb 25, 2001 08:47 PM
Andrew91SE
Nov 26, 2000 03:05 AM
ohboiya
Oct 9, 2000 12:23 PM
