Throttle Plate Open
Throttle Plate Open
i just checked my throttle plate for any residue, and its open a notch, usually it should be closed all the way when the car's off!? i can see that it remained open.
how can i adjust it?
can i?
its a drive by wire system
please help
can i?
please help
Originally posted by BigDogJonx
How much do you mean open a notch? If it were truly open, it would be idling well around 1500-2000rpm.
If you idle fine right around 750rpm, then you have no problem.
Dixit
Dixit
it idle's at 1000-1100, even after driving for awhile it still idles at 1100 rpm, if i let go of the brake it will drive! it goes to about 15mph unless i hit the brake, i dont even have to hit the gas to move haha, i have to put it in neutral or else it heats up my tq convertor, it just stays revved.
i thought the 2k2 was drive by wire electronic throttle, whats up with the idle speed? it should be auto!?
** UPDATE **
Dealer checked it out:
P0507-SHORT IN THROTTLE CHAMBER
REPLACED EFI THROTTLE CHAMBER (DBW THROTTLE BODY)
REPLACED THROTTLE BODY GASKET
CONSULT ADJUSTMENTS
1.9 HOURS
PARTS $804.30
LAB-MECH $151.20
TOTAL $955.50
GREAT SERVICE, CAR RUNS MUCH BETTER, AND EVEN SMOOTHER THAN BEFORE. TECH SAID MAYBE K&N OIL GOT IN BETWEEN PLATE AND SHORTED IT, OR TB CLEANER SHORTED IT OUT
CONSULT ADJUSTMENTS
1.9 HOURS
PARTS $804.30
LAB-MECH $151.20
TOTAL $955.50
Re: ** UPDATE **
CONSULT ADJUSTMENTS
1.9 HOURS
PARTS $804.30
LAB-MECH $151.20
TOTAL $955.50
CONSULT ADJUSTMENTS
1.9 HOURS
PARTS $804.30
LAB-MECH $151.20
TOTAL $955.50
Easy on the caps next time, it's almost as if you are yelling.
Re: Re: ** UPDATE **
Originally posted by foodmanry
Isn't it under warranty?
I paid $0.00
was typing it at 100wpm, when i looked up and saw CAPS, it was too late, didnt want to go back and type it over.
Re: Re: Re: ** UPDATE **
just an FYI...
Re: Re: Re: Re: ** UPDATE **
Originally posted by jjs
No need to type all of it. Just copy and paste to Word, use 'Format' and 'Change Case'. Make the changes and paste back to the forum.
just an FYI...
just an FYI...
If only I knew that last week!!!! I could have changed case and saved myself alot of time, had to cite over 200 words, but they were all in caps, I typed all of it!
Re: Re: Re: Re: Re: ** UPDATE **
ahhh, learn something new everyday!!!!! LOL!
... I'm just messing with ya
Re: Re: Re: Re: Re: Re: ** UPDATE **
Originally posted by Chinkzilla
Did you know also that if you hold down the shift key while hitting a key it changes case for you? No need to hit capslock all the time!
NO ****! WOW! ALL THIS time I've been HiTTiNG The caps lock key! man
knight_yyz
Nov 1, 2015 01:34 PM
That's some $$$ . Now I'm scared to clean my throttle body even though its not DBW. Although the explanation about oil from the K&N, they need to come clean it up(BS).
