writeup for injen install on a 2k1?
Old Feb 21, 2003 | 01:11 PM
Wasim521's Avatar
Hey...I found Greg's install of an injen intake on a 2k2, but is there anyone with detailed pics/writeup of an install on a 2k1 or 2k?
Old Feb 21, 2003 | 02:07 PM
BigDogJonx's Avatar
Aint nothing to it partner, just remove the stock intake and put in the injen. It has one bolt that attaches to the engine block.
This by far one of the easiest installs behind the FSTB.
Dixit
Old Feb 21, 2003 | 02:25 PM
foodmanry's Avatar
Da Roller Coaster!
You have to remove the intake all the way to the throttle body. You also have to remove that resonator box (white) located under the battery. You pretty much have to remove the battery altogether to get the resonator box out. With the battery removed you can easily bolt on the Injen intake. If they didn't supply you with directions then call them and have them fax or mail them to you if you really need it. But like Dixit said, it's one of the easiest installs especially with the battery removed. I would clean your throttle body while you have the stock intake off, before you put the Injen intake on. Chances are if you haven't cleaned it yet, it probably has a black ring around the edge of the inside.
Old Feb 21, 2003 | 02:38 PM
Wasim521's Avatar
Thanks guys...just wanted to know what i'm getting into, and now I do
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
