Tweeter crossovers?
Old Feb 28, 2003 | 05:09 PM
Slime's Avatar
Tweeter crossovers?
I was just wondering if the tweeters in the A-pillars on a 2k have crossovers or just caps? Also, are they wired as a separate channels from the headunit or are they spliced into the channels for the front door speakers?
Any help on installing an aftermarket system in a 2k would be appreciated.
Thanks!
Old Feb 28, 2003 | 06:59 PM
PoLo's Avatar
2-Wheelin it...
Re: Tweeter crossovers?
Thanks!
1) yeah, but if you wanna call it a xover...it's a low frequency resistor to avoid distortion. i swapped it for some cheap kappa tweets and it improved, although when i do put it real loud, it distorts more than the stock cause the resistor went with the stock tweet.
2) they are tapped into the front speakers.
Old Feb 28, 2003 | 09:40 PM
TimW's Avatar
The silent but deadly Moderator
they just use caps, 3.3uF
Old Mar 1, 2003 | 06:18 AM
spta97's Avatar
Re: Re: Tweeter crossovers?
You can install a cap (for pennies) in-line on the positive terminal. That will cure your problem. You could also get a "bass blocker" which is a more expensive version of the same thing.
melteye
May 16, 2016 12:02 AM
vybz05
Dec 10, 2015 07:38 PM
95naSTA
Sep 21, 2015 06:50 PM
MikesChevelle
Aug 9, 2015 11:50 AM
Adam01GXE
Mar 22, 2001 03:45 PM
