Grinding sound on cold starts
Old Mar 3, 2003 | 12:41 PM
SkoorbMax's Avatar
I have an 00 SE. I bought it with 37k miles. It has 42k now. Since buying it when the engine is cold very ocassionally (on average one out of 10-20 starts, though sometimes a couple in a row) I'll get a grind when it starts. It's not while the crank is turning - but rather once the engine has started and the RPM peaks at that exact moment is the grind for a split second. I was told that it's probably the timing chain tensioner, and given how infrequently it happens I should just let it go for now.
Has anybody else had this and would powertrain cover it if I could manage to get a mechanic to confirm the problem (which would be difficult)?
Old Mar 3, 2003 | 01:46 PM
Zog's Avatar
Zog
Re: Grinding sound on cold starts
You can search for "timing chain rattle" and find your answers. But the bottom line is:
[nissan employee voice] it's normal [/end nissan employee voice]
Old Mar 3, 2003 | 02:25 PM
TimW's Avatar
The silent but deadly Moderator
sounds like the starter soleniod sticking.. pretty common..
Old Mar 3, 2003 | 06:19 PM
foodmanry's Avatar
Da Roller Coaster!
I had the same problem on my 2000 GLE. It was due to the starter. I fixed it by removing the starter and regreasing everything inside. It took about an hour and a half and some patience. I did a write up on how to do in the "installation/how-to" thread at the top of the forum.
Hope this helps!
markevans999
Sep 10, 2015 04:29 PM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
