trunk ratling
Old Mar 11, 2003 | 10:03 PM
bdog's Avatar
trunk ratling
I got some kick as sux but my rear deck seems to rattle a lot. I fully dynamated my trunk but it still seems to rattle. Especially the deck, now I was told I can't dynamat the deck since it's cardboard material it will still pop up and down any other suggestionS?
Old Mar 11, 2003 | 10:22 PM
VMaximus02's Avatar
Re: trunk ratling
You can use the carpet padding for the task. Was the weather cold when you experience the rattles? My rear deck was annoyingly rattled a couple of weeks ago...and I later found out the cause, which was the sheet of ice forming behind the rear trunk lid.
Old Mar 12, 2003 | 08:54 AM
bdog's Avatar
Re: Re: trunk ratling
It's been giving me this problems since summer when i got my subs
Old Mar 12, 2003 | 10:36 AM
spta97's Avatar
Re: Re: Re: trunk ratling
I, as well as many others, have had luck using a foam mattress pad (egg crates). You can pick up a twin size for about $10 at Wal*Mart or K-Mart. ( Leave off the last "s" for savings! ) Just cut it to size and use some 3M spray glue to keep it in place while you are installing. Got rid of all my rear deck rattles. And if you haven't already done it, remove the Bose sub off of the rear deck...will give a nice bass port and a with real subs that thing is useless.
Old Mar 12, 2003 | 11:17 AM
lophix's Avatar
Re: Re: Re: Re: trunk ratling
or you can get 3m rubberised coating from walmart for 6bucks and spray 3 layers on...that works too.
REDinLV
Aug 15, 2024 12:30 AM
mrgooch
Sep 21, 2015 08:43 PM
lux97Max
Sep 14, 2015 07:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
