Bizarre window problem with brand new 2003 GXE
I bought another Maxima last night (2003 GXE with no options except painted mud flaps, floor and trunk mats for $21,395+ttl -- Herb Gordon Nissan in Maryland) and uncovered a bizarre problem when I got home. I turned the ignition key to the "off" position and removed the key from the ignition. This caused the front windows to roll all the way down!
I tried it again and sure enough, it happened again. I spent a few minutes swearing, and then tried it again. This time, the windows didn't move; so I opened the door to exit the vehicle and then the windows went down, starting at the moment that I opened the door. I wonder if the wires that drive the window relays have come into contact with some other wires that go hot upon opening the door, and/or removing the key from the ignition, etc.?
I tried it again this morning, and the problem still exists (it wasn't a dream, unfortunately). Seems to have settled on lowering the windows when I open the door, and not when I remove the key from the ignition. The good news is that it happens 100% of the time (nothing worse than an intermittent electrical problem that can't be reproduced).
A local dealer wants to see the car as soon as I can bring it in. I guess they get 4 chances to fix it over the next 15 months according to the Maryland Lemon laws, but hopefully it's something simple.
Any suggestions on where I should have the technician focus? I would like it fixed the first time since it is very inconvenient to have my car in the shop.
Thanks,
Mat
Thanks,
Mat
Re: Bizarre window problem with brand new 2003 GXE
Thanks,
Mat
Thanks,
Mat
SECU is toast..
-OR- your car was vandalized for the HIDs. One of the things they do when stealing HIDs is pop the driver door lock and access the window control wires in the doors.. they short them and the windows roll down. That could also toast the SECU. or leave it really freaked out
You need to inspect the wires for the headlight harness. they shouldn't be yellow. Check you door for pry marks or repairs.
Get a discount, free extended warranty or a lawyer.. or all three..
Re: Re: Bizarre window problem with brand new 2003 GXE
Originally posted by MaximaZero
I have the feeling that maybe the unlock button on your keyfob might be stuck since holding down the unlock on the keyfob rolls down the windows. That would explain why it happens right after you pull the key out of the ignition due to the fact that the keyfob doesn't work unless the key is out of the ignition.
Thanks,
Mat
If you just got it last night, you still have time to back out on the deal. I think you have up to 3 days. If you suspect any problems, take it back and get a different car. I would not want my day old car in the shop for electrical issues.
i didnt no holding down unlock rolls down the windows! how come no one ever told me
Thanks,
Mat
Thanks,
Mat
Re: Re: Re: Bizarre window problem with brand new 2003 GXE
I took the car to the Nissan dealer and they couldn't fix it in 2 hours, so I had to leave it with them. Thank god I have an extra car for the next few days while I am waiting for my car to sell.
They think they know what the problem is, but apparently the testing to confirm the problem takes some time. They should be calling me today with the answer.
re: 3-day "cool off" period -- doesn't exist in Maryland. The dealer that I bought the car from has offered to drive down, leave a loaner car, and take the car back and get it fixed. So I think I am covered.
I didn't have time to check the light harnesses, so I will have to hold on to get the car back. The dealer said that the car was new, and wasn't damaged, and visual inspection doesn't offer any clues.
The only good news is that the problem happens 100% of the time, so they will know for certain if they have fixed it.
I'll post a final resolution when I have something from the service dept. Maybe this problem is what I get for buying a 2003 GXE for $21,395.
Ciao,
Mat
Ciao,
Mat
I will get as much detail as possible. If I have evidence that suggests the vehicle was damaged while on the lot, I will demand some sort of compensation depending on the type of damage.
FWIW, the dealer said they don't see the headlights being stolen, especially given that so many cars have them today. He did say they do have cars stolen and blamed their proximity to Baltimore; I would imagine that parts would get stolen as well therefore.
I guess I should be looking for unevenness of the door metal around the locks, re-painting evidence, as well as "hack" marks on the headlight harnesses and/or splices in the headlight cables?
Can a dealer sell a refurbed car as new? Sounds illegal to me. For example - new cars that sustain hail damage and are repaired are not sold as new.
tnx,
Mat
tnx,
Mat
...Can a dealer sell a refurbed car as new? Sounds illegal to me. For example - new cars that sustain hail damage and are repaired are not sold as new.
tnx,
Mat
tnx,
Mat
Well..
It happened to me.. I got a new Max from a dealer that had previously had its lights stolen and replaced.. I'm still trying to combat this, but not getting anywhere. NNA says they can't do anything and the dealer claims he "can't see any signs of previous work" when i point out obvious things..
Check out this thread: http://forums.maxima.org/showthread....ID+springfield
Later,
Nick
Later,
Nick
I spoke to the service guy and they believe they have diagnosed the problem.
A part (part no. 806032Y911) called a "switch assembly" and also known as a "body control module" is defective and behaving as though the key has been inserted in the lock, turned and held in the unlock position, causing the windows to lower.
Been in the shop for 2 days and should be fixed and ready for me to take home this evening.
I'll check the headlight wires when I get the car back and hope they are not the yellow ones...
Ciao,
Mat
Ciao,
Mat
THIS is exactly hapennning to me TOOO, and sometimes, when I Auto pop-up, it comes back down a little.
Oh my god, they opened when I was sleeping once, and were open the whole night. Now, it was open all morning today. Then, when I went out to wash the car and closed the windows, a minute later they opened again....what the hell!?
Weird power window behavior in the maxima is not uncommon. Several people (me included) have reported unintended window activities. My driver window will not stay closed if I use the auto-up feature--as if there is an obstruction, which there is not. This sort of behavior has been reported several times here. I have heard of no-one who was delighted with the dealer's attempts to repair this. This is just one of the problems I intend to address when my maxima goes in next month. Sadly I must say that my '03 SE has more problems than any other new car I have ever owned. I thought I was avoiding this sort of thing when I chose the maxima over the Jaguar x-type.
Quickgtp
08-27-2015 02:13 PM
