How do you adjust the angle of the HID lights?
Old Mar 21, 2003 | 08:39 AM
UCF_94lude's Avatar
I remember seeing someone did this so that more of the light is concentrated higher up, resulting in better overall vision.. how is this done? Can a novice do it safely?
Old Mar 21, 2003 | 08:47 AM
t56gen3's Avatar
Re: How do you adjust the angle of the HID lights?
I changed mine without an issue. I could only find a "height" adjustment, not a side-to-side adjustment though. Just be careful around them and you should be fine. I used a 1/4 rachet and an 8mm socket to turn the adjuster (white with gear-teeth on the sides, but hex on top). I have made several adjustments (fine tuning, its fun to **** off oncoming traffic) without a problem.
The factory setting for my car was damn near on the ground! (No really, only about 20 feet out)
Old Mar 21, 2003 | 09:08 AM
UCF_94lude's Avatar
Sweet, so its actually factory adjustable! What do I look for on the lights for adjustment. I havent actually looked yet, but I will when I get home tonight. Up and down is all I wanted to adjust. Its just too low right now.
Old Mar 21, 2003 | 09:13 AM
t56gen3's Avatar
Granted, it's been a month since I looked under there, but, if memory serves, most the headlight assembly is black and the adjusters are white. The "heads" of the adjusters face back towards the firewall. I had to push the wiring a little back and forth on the drivers side to see it. The pass side was cake. All and all, very easy to do.
Old Mar 21, 2003 | 09:17 AM
maxcosity's Avatar
yeah im going to raise mine up tonight a little bit, too -- it's just too low!!
look on the back of the headlight house.. there's some gears -- you want the gears to move one way for up and another way for down..
Old Mar 21, 2003 | 09:30 AM
BigCmax
Re: Re: How do you adjust the angle of the HID lights?
Are you sure the socket is 8mm I thought it was 10mm.. Not hard to find out. Also which way raises the beam? Clockwise or counter clockwise? Does a 1/4 turn or 1/2 turn make a noticable difference? I just don't want to mess around with them too long.
Old Mar 21, 2003 | 09:35 AM
t56gen3's Avatar
Re: Re: Re: How do you adjust the angle of the HID lights?
You may be right on the socket size, but for some reason 8mm sticks out in my head. Counter-clockwise raises em, and the ratio of turns to lift is kinda slow.
In my case I had one headlight higher than the other from the factory, so I adjusted it higher and higher (pulling over and stopping and making changes) till I got it where I wanted it. Then I parked behind my garage as far away as I could and left the door down, and matched the height on the other one. (Being a perfectionist sux!)
Old Mar 21, 2003 | 11:40 AM
max...to the ma's Avatar
really? how much better did they say it was?
Old Mar 21, 2003 | 12:37 PM
UCF_94lude's Avatar
they just said that it was much better visibility because they are pointed towards the ground too much, IMO. I have been in many other cars w/HID and the visibility is definetely better becase of the angle of the lights.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
