OK... what can replace this Bose crap??
ok...
im sick of the left side speakers goin in and out
if i get a new headunit...
will it run the speakers?
info on changing this will help me alot ....thanks!
Re: OK... what can replace this Bose crap??
Originally posted by 2k2PhatMax
ok...
ok...
![Mad](https://maxima.org/forums/images/smilies/mad.gif)
[QUOTE]Originally posted by 2k2PhatMax
[B]ok...
Assuming the 2k2 and 2k3 Bose system are the same---the Bose amp in the trunk drives all the speakers. Most likely, you have a bad amp that is over heating and shutting down the left channels, or you have a speaker that is shorting and shutting it down (I used to be an installer.) Changing the head unit will probably not do anything for you. (It is possible that it is the head unit, though it would be uncommon since it's just a source unit.)
The cheaper solution is what I did: replace the front speakers and rear sub with new speakers and amp! Kept factory ID 6 Disc and steering wheel controls, much better sound and volume.
Good luck!
[B]ok...
Good luck!
i know that the problem is with the head unit b/c i can hit it a couple times and the left speakers come back on!!
i want to know if an aftermarket HEAD UNIT WILL POWER THE BOSE SPEAKERS?
or will it work with the bose amp
Originally posted by t56gen3
It will require integration. The Bose amp uses 5+ volt input. It will require an adapter of some sort. You will most likely lose your steering wheel controls if you change. I would suggest you try to get the factory unit warrantied if you haven't already. Aftermarket radio will look like crap in that car, and unless you want to spend a grand on something sweet (DVD), then you probably won't like the outcome. A custom kit can be built, but it will cost ya.
i wish i had the search fuinction i could show you..
so adapter for 5 volts?
anything else?
i have a 7 ich DVD system on the way... and there is something you can buy to keep controls on the wheel...
anything else?
anything else?
I can find out for sure for you if you wish what all you will need in a little while when my friend's stereo shop opens--let me know if you need it.
Have fun with the DVD! That will be a fun toy.
ok...
ok...
ok...
The problem is in a cable that is inside the HU. The cable carries the signal from the shock-mounted CD laser assembly to the circuit board where the pre-amps are located. The cable design was defective. Clarion is replacing the defective cables with new ones, and placing a new sticker on the repaired units. Again, make sure the dealer checks for the manufacturing date (or the repaired sticker).
As for replacing the HU, you can replace it with an aftermarket one, while keeping the Bose amp/speakers, but you'll need a few parts. PAC's ROEM-NIS2 kit and the SWI-X kit. Read the Audio forum's FAQ for links to threads on how to replace the Bose HU. I would get a corrected unit BEFORE replacing it. I replaced my HU even AFTER I got a corrected unit (and no, my HU is NOT for sale). I still have the stock Bose amp/speakers, with no problems.
6spd4dsc
05-09-2022 12:30 PM
