Resetting sunroof?
Resetting sunroof?
Hey guys, unfortunately I cannot search for my question, so maybe soemone can answer for me. I saw a thread on here a while back about how to reset your sunroof (2k2) when it "forgot" where it was. I had it open when I disconnected the battery to install my stereo, and now it's completely confused. I can just disconnect the battery again and see if it resets correctly, but I thought there was an official procedure? Thanks in advance.
It's in your owners Manuel. Here is the procedure:
The sliding switch will become inoperable after the battery terminal is disconnected, the electrical supply interrupted and/or some abnormality detected. Use the following re-set procedure to return sunroof operation to normal.
1. If the sunroof lid is open, push the tilting switch repeatedly toward tilt DOWN to fully close the lid.
2. After the lid has closed all the way, keep pushing the tilting switch toward tilt DOWN for more than 1 second.
Maybe we can get a moderator to add this to the FAQ? I know I'm not the first person to ask this. It doesn't sound like something you would normally find in your user manual, so I didn't bother to look there. Thanks again!
Forge277
Jun 13, 2016 09:26 PM
