Speaking of Ghetto Air Box
Old Mar 30, 2003 | 08:11 PM
  #41
Y2KSESteve's Avatar
Originally posted by BlackMax2k1
If I had to buy the piece again you cut, how much do you think that runs for?
Old Mar 30, 2003 | 11:59 PM
  #42
HitManSE's Avatar
OMG, Dave H is probably laughin at the top of his lungs right no since hes the 1 who created this. Im probably gonna just leave mine alone for the time being but will definetly to the quote to dave "GAB" mode on my next ride. Btw steve 2K2 6spd is 3rd behind Emax in trap, Dave H ran a 102 trap the other night which I belive topps Ethan, I think he ran a 101 somehthing. Ill be going those #'s soon enough.
Old Mar 31, 2003 | 12:31 AM
  #43
Y2KSESteve's Avatar
I'll believe it when I see it....oh and when im boosting, i will too.
Old Mar 31, 2003 | 05:47 AM
  #44
Bluesbrekr's Avatar
Doctorate in Detailing
I checked with my local Nissam Dealer...They said $87!!!!
Seems a bit much for just the air filter frame, but that's what they want.
Old Mar 31, 2003 | 06:42 AM
  #45
2K2_6spd's Avatar
Try some boneyards. The filter framees are interchangeable from 2000-2003.
Old Mar 31, 2003 | 07:12 AM
  #46
2000 SE's Avatar
Actually, I think that if you put 2k2_6spd's car at the same track it would be quicker than Emax's. Remember that firebird is about 1500ft above sea level, which is hurting 2k2's mph by about 1-2mph!
If you do the same math on my 2000 it would equate to almost 96mph in the 1/4 with basically a stock 2000 5sp!
Old Mar 31, 2003 | 09:03 AM
  #47
Dave B's Avatar
Not DAVEB the parts guy
I'm a firm believer in this style of airbox. I did this to my 4th gen's airbox a few months ago and I've been happy ever since. Yesterday I ran a 14.45@99.5mph with this style airbox. No resonators, K&N filter panel, and a cut in the lower airbox. My car seems to run better at all RPMs plus the airbox sounds much more healthy than the HKS hybrid setup I had.
FYI, this setup has been know as the "hacked" airbox by other members and it's been done for years now at Maxima.org.
Dave
Old Mar 31, 2003 | 09:09 AM
  #48
clipse's Avatar
Dave
Will all the problems with MAFS when running an aftermarket air intake I'm seriously interested in performing the "hacked" airbox mod. I own a 2003 maxima was wondering if any fellow Org. members can give me the required info on how to perform this mod. Thanks in advance.
Old Mar 31, 2003 | 09:41 AM
  #49
maxman00's Avatar
Originally posted by Y2KSESteve
Yea its not tough at all. This is by far the easiest intake to install/make/customize.
Where are you planning to route the hose? Is there a way to bring it around to the front?
Old Mar 31, 2003 | 11:42 AM
  #50
Y2KSESteve's Avatar
The bottom of my front bumper. It wouldnt be hard for me at all because like I said, I already have a hole in the bottom of my stock scoop where the resonator attached.
Old Apr 1, 2003 | 11:42 PM
  #51
clipse's Avatar
Anyone .....
Old Apr 2, 2003 | 03:31 AM
  #52
blu02's Avatar
http://forums.maxima.org/showthread.php?threadid=33563
also known as OSCAI (oogly-ugly stock cold air intake) it should be on page 1. there are 3 write ups on it.
Old Apr 2, 2003 | 06:50 AM
  #53
HitManSE's Avatar
Anyone .....
Look at Daves home page. http://www.cardomain.com/member_page...=213296&page=3
That small peice were the OEM air filter goes into, u remove that and the filter is relaced with a K&N. If u look at the pics ull see were he cut it. Dont use a powered tool cuz its plastic and its gonna get hot, melt, ect... and just gonna make a mess. U basically cut off front portion of it to make way for more air to come in. Like I said look closley at the pics. The second thing is that snorkle in the front of the engine bag, remove is and the peice stickin out of the botton must be cut open from the end. Afte that slap on a 3" dryer exhaust onto it and aim it to the front bumper so it brings the air to the box. Think thats bout it.
Old Apr 2, 2003 | 07:36 AM
  #54
jjames's Avatar
Why bother removing the snorkle in front of the engine bay? And what piece sticking out of the bottom are you talking about? The elbow that goes from the bottom of the intake to the silencer? Don't cut it, just take it off.
Old Apr 2, 2003 | 09:35 AM
  #55
HitManSE's Avatar
I used to say that too, but u can actuallu use that to your advantage and have it guide air to the box. From the front as well as the bottom with the 3" tube. It will basically be kind of a ram air setup not exactly but the air will always be rushing to the filter this way. Just my .02
Old Apr 2, 2003 | 11:46 AM
  #56
Y2KSESteve's Avatar
I used a dremel and mine looks awesome. But yea, just cut it out, remove the elbow and rout some sort of tube to the front bumper. I have a couple more pics on my homepage of it if youd like to check them out, page 3.
Old Apr 2, 2003 | 12:39 PM
  #57
maxman00's Avatar
do you have any pictures of where you routed the tube?
Old Apr 2, 2003 | 12:42 PM
  #58
Y2KSESteve's Avatar
I havent routed the tube yet. I'm hesitant to use the dryer tubing because its metal and will absorb a lot of heat. I'm trying to come up with something that will be more efficient and keep the air cooler. When I'm done with it I'll be happy to post some pics.
Old Apr 2, 2003 | 01:23 PM
  #59
maxman00's Avatar
I was just curious, because I too have something in mind. I don't think it will be possible to route anything to the front of the bumper. From what I have seen most people just attach it to the splash guard. I think that helps, but I would like more of a ram effect with out cutting into anything. We shall see....
Old Apr 2, 2003 | 01:25 PM
  #60
Y2KSESteve's Avatar
Yea, I took off my splash guard and I'm going to attach it to the bottom of the bumper.
Old Apr 2, 2003 | 02:27 PM
  #61
jjames's Avatar
Are you worried about water at all?
Old Apr 2, 2003 | 02:51 PM
  #62
Y2KSESteve's Avatar
Not in AZ!
Old Apr 2, 2003 | 04:41 PM
  #63
2K2_6spd's Avatar
I used the wire reinforced, vinyl tubing for my scoop.
Old Apr 2, 2003 | 05:03 PM
  #64
maxman00's Avatar
Where did you route the tubing? Or, how did you set it up to maximize air flow?
Old Apr 3, 2003 | 01:25 PM
  #65
Mkang513's Avatar
Just did the GAB mod. Not as loud as i expected. Definietly not as loud as my bro's PR intake. I guess I'll go ahead and do the Ooglie intake. For those that wanted another link, Bigdogjonx has one on his site.
Old Apr 3, 2003 | 01:51 PM
  #66
jjames's Avatar
Right here: http://www.bigdogjonx.com/oscai.html
Perfect explanation. Simple, easy.
Old Apr 3, 2003 | 01:52 PM
  #67
BlackMax2k1's Avatar
I'm skeptical on the loudness of the GAB. Some people said
it was as loud as the Frankencar.
Old Apr 3, 2003 | 02:00 PM
  #68
jjames's Avatar
It's not. If you floor it, you can hear it. It's definitely a deeper sound at WOT. But under normal driving conditions, it's no differerent than stock.
Look, just go take the insert completely out, put the filter in without the insert, get it to stay in place, and drive around the block.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Sep 27, 2015 08:37 AM
