TOKS are IN!!
Old Apr 2, 2003 | 10:48 AM
skandalouz's Avatar
TOKS are IN!!
anything i should know before i get my friend to install them? i'm putting them on with tein s.tech springs. is there anything else that i need to buy.. or any shortcut tips anyone can give me?
Old Apr 2, 2003 | 11:01 AM
Igor911's Avatar
Re: TOKS are IN!!
Yeah maybe a camber kit
Old Apr 2, 2003 | 11:45 AM
skandalouz's Avatar
Re: Re: TOKS are IN!!
should i buy it before and install everything together... or is it an easy install.. so i could install my springs and shocks first.. and just add the camber kit later?
Old Apr 2, 2003 | 11:57 AM
Y2K2Driver's Avatar
Re: Re: Re: TOKS are IN!!
If you get a camber plate, best to put that in at the same time since you would have to remove your front struts and disassemble them again. Howver, you probably only need camber bolts which are pretty easy to put in since they simply replace the upper most bolt holding the strut to the hub. You might as well do everything at the same time though.
Old Apr 2, 2003 | 03:47 PM
skandalouz's Avatar
Re: Re: Re: Re: TOKS are IN!!
where can i buy these camber bolts?
Old Apr 2, 2003 | 03:52 PM
Y2K2Driver's Avatar
Re: Re: Re: Re: Re: TOKS are IN!!
Tirerack sells the Eibach camber bolts which are good for +/- 1 degree of camber. Ingalls also makes camber bolts and they offer +/-1 and +/-2 bolts. www.civicshop.com offers them as I'm sure many other places do. If you check out the group buy for the Tokico struts, Ray from civicshop gives the prices for each since I initially inquired about them. I'm not sure what is need for the Tien springs though so you best ask someone who has them.
Old Apr 2, 2003 | 07:07 PM
02'maxed-out's Avatar
Don't buy a camber kit. It is not worth the money. Trust me, I have dealt with many numerous people with camber kits and they all, I mean all say its not worth it. Eventually your camber kit will break and hopefully when it does that, it doesn't rip your fender wall or cause a flat tire. Plus, I have teins with toks too, and they drop low, but not that low. Save your dough!!!
Old Apr 2, 2003 | 07:20 PM
Y2K2Driver's Avatar
Bolts are no more than $20. Hardly a waste if it allows for correct alignment.
Old Apr 2, 2003 | 07:41 PM
camber bolts= okay.... camber kit= waste of money
I30tMikeD
Feb 26, 2004 07:28 AM
96bstdSE
Jun 19, 2003 11:10 AM
HitManSE
39
Mar 24, 2003 08:55 AM
acts13
Jul 15, 2002 07:00 AM
noflash
41
Jun 19, 2002 09:29 AM
