got some engine codes after i scaned the engine light... dont know what they mean...
Old Apr 5, 2003 | 04:59 PM
a33's Avatar
a33
p0180: this stands for the fuel temp sensor, but i have no idea what it means...
p1165: no idea at all
p0464: no idea at all...
anyone know what they mean???
thanks
Old Apr 5, 2003 | 05:11 PM
cabernet's Avatar
Re: got some engine codes after i scaned the engine light... dont know what they mean...
thanks
According to actron.com the P0464 means:
Fuel Level Sensor CKT Intermittent
Doesn't mean much to me
Old Apr 5, 2003 | 05:26 PM
UMD_MaxSE's Avatar
Got Bent?
P0180 = Fuel Tank Temp Sensor
P1165 = Swirl Control Valve (Cali Spec only)
P0464 = Fuel Level Sensor Circuit
The P0180 and P0464 indicate something wrong with the sensors in the fuel tank itself. Either the sensors themselves are bad, or the readings they are putting out do not make sense in relation to the engine coolant temp and/or the intake air temp (as measured by that sensor). Have you been messing around with your fuel pump assembly?
The P1165 seems to be simpler... check the vacuum line connecting up to the swirl control valve (cylindrical plastic piece near driver side strut tower) and all other vacuum lines. If your lines are not hooked up correctly, your swirl control valve will not operate correctly and the butterfly valves in the intake manifold will not open up. Your car will be really slow past 3k rpm so you will know right away if that is the problem...
derekinthez
Nov 13, 2022 04:00 PM
mvm062
Nov 30, 2020 09:00 AM
gustavison
Oct 4, 2015 06:50 PM
seesole
Sep 14, 2015 12:38 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
