Suspension Setup Questions for 2K2
Unfortunately, I can not search yet, so I need some help with setting up my suspension:
1. How does the Maxima ride with GR2 struts and OEM springs, does the ride firm up or does it stay "floaty".
2. I could install used H&R springs with GR2 struts, do I need to be concerned about installing the used springs? Do the "wear out" or will the spring rate remain constant over time?
Thanks in advance!
Thanks in advance!
Re: Suspension Setup Questions for 2K2
Thanks in advance!
Thanks in advance!
Used H&R springs should be fine. Just make sure they aren't cut, unless you want cut springs. Right now I have a 2k2 with Tokico blues and H&R springs and it is a nice ride. It rides nice and def. improved the handling a ton.
Re: Re: Suspension Setup Questions for 2K2
Re: Re: Re: Re: Suspension Setup Questions for 2K2
Originally posted by asu174
No. Not at all.
No. Not at all.
I noticed on your home page that you are running KYB shocks. Are they the AGX or GR2 and do you have experience with the GR2 as they compare to the Tokico blues?
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
11-06-2015 02:34 PM
Violator
09-09-2015 10:14 AM
