Wheel Torques ???
Old Apr 12, 2003 | 11:55 AM
Grog's Avatar
Wheel Torques ???
Hey everybody, I'm a newbie here, just found the site. (I've got a 2001 Merlot SE stick)
Sorry if this has been asked before, for some reason I'm not able to use the 'search' feature (I just registered). Anyways, I'm about to put my summer wheels and tires back on and wondered if anybody knew the correct torque specs for them (they are the 17" nissan wheels)?
Any help appreciated! Thanks!
Grog!
Old Apr 12, 2003 | 12:07 PM
griffy2k2max's Avatar
The Torque is 80 ft-lbs
Old Apr 12, 2003 | 01:07 PM
Grog's Avatar
Thanks Griff!!
Old Apr 13, 2003 | 05:06 AM
Originally posted by Grog
Thanks Griff!!
No Problem!
Old Apr 13, 2003 | 12:38 PM
RT03SE's Avatar
Once properly torqued do they stay that way or is there a possibility they loosen up?
Old Apr 13, 2003 | 01:00 PM
asu174's Avatar
Clay Aiken has fancy genitals
There's always that possibility, but I wouldn't worry about it.
Old Apr 13, 2003 | 07:12 PM
Highly unlikely
Old Apr 14, 2003 | 11:30 AM
raiste's Avatar
I have a 2k3 (GLE) with the stock 17" rims, is the lug nut torque the same for me?
Old Apr 14, 2003 | 03:39 PM
kwd2kSE's Avatar
Yes. Plus the specs are listed in your owner's manual.
Old Apr 14, 2003 | 04:13 PM
maxcosity's Avatar
What about for aftermarket wheels or is 80lbs. pretty common?
Old Apr 15, 2003 | 10:12 AM
raiste's Avatar
Thanks, I guess I should have looked there. Not used to manufacturer's putting that kinda info in the manuals.
Old Apr 15, 2003 | 10:15 AM
raiste's Avatar
I think I read somewhere that you should re-torque the lugs about 500 miles after you have put them on. For example, if you rotated your tires at 5,000 miles, then at 5,500 miles you should re-torque them.
Old Apr 15, 2003 | 10:34 AM
kwd2kSE's Avatar
NO. It's recommended that you re-torque alloy wheels after 25 to 50 miles after you remove them for any reason.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
240tomax
Sep 13, 2015 03:28 PM
dcam0326
Sep 8, 2015 11:02 PM
