UDP Install Help
Old Apr 14, 2003 | 04:57 PM
VQ30GTR's Avatar
UDP Install Help
Hey everyone,
Tried to install my UR pully this weekend. I have a 2K1 Auto. Does anybody have the instructions from the service manual on the proper way to remove the crank pully? If you have it in a .pdf, that would be great. I tried with my impact wrench, and had no luck budging the bolt. I soaked it with liquid wrench, still nothing. So I tried the starter one, hesitantly, as I do not like that way of removing something. So I blipped the starter, and proceded to crack the side of the impact socket. So I have found a shop that says they can do it, but I would really like to have the factory service page before hand. Can anyone help?
Thanks!
Old Apr 14, 2003 | 07:43 PM
02MaXiMa_GLE's Avatar
Re: UDP Install Help
STUDMAN has AWESOME instructions on hie webpage for the 2k2-up UDP installation.
STUDMAN's SITE
G
Old Apr 15, 2003 | 09:53 AM
VQ30GTR's Avatar
Thanks, I have seen it, but I am a 2001.
Old Apr 15, 2003 | 10:05 AM
Maxman2000's Avatar
Which reminds me to ask, is there a way to lock up the flywheel on an auto. like a little access plate (which reveals the flywheel teeth) on the bell housing???
Old Apr 15, 2003 | 10:13 AM
Jime's Avatar
I have removed both with the started method and an impact wrench. However I had one that would not even budge, I could hold the starter and it would just torque the engine also tried with a 650 lb torque wrench and still not go. Finally had to heat the bolt with a torch and it came off.
It all depends on who put it on last and if they used loctite or if never taken off, some are just VERY stubborn.
Old Apr 15, 2003 | 02:12 PM
Maxman2000's Avatar
You have to take the starter off???
Old Jul 1, 2003 | 12:39 AM
aznsap's Avatar
i see you ahve an auto. how did you get the bolt torque'd back on the pulley??
Old Jul 1, 2003 | 02:19 AM
MrGone's Avatar
put the car in gear.
park is not in gear.
neutral is not in gear.
R/D/2/1 is in gear.
Old Jul 1, 2003 | 09:52 AM
bigdo26's Avatar
I'm probly gonna install my UDP this afternoon with a buddy of mine. I got the directions from STUDMAN's website, they seem like perfect instructions, just reading over them here at work. Any other advice though would be great for helpin my thru the install.... How long would you expect it to take following the writeup studman did? seems the only thing i have to worry about is getting a bolt or two off...
Old Jul 1, 2003 | 10:25 AM
Jime's Avatar
No I used the starter method to remove the bolt.
Impact wrench and a good guess.
Old Jul 1, 2003 | 10:29 AM
aznsap's Avatar
nooo... if you have an auto, it'll be a little different than studman's site. he has a 6 speed.
Old Jul 1, 2003 | 02:01 PM
bigdo26's Avatar
ah his is a 6 speed... i missed that part. how is it different?
Old Jul 1, 2003 | 03:32 PM
ru4real's Avatar
Putting the automatic transmission in gear won't keep the crankshaft from rotating. You have to open the access panel and prevent the flywheel from rotating somehow. See bigdo26's other thread and/or search if you can.
Old Jul 1, 2003 | 06:29 PM
VQ30GTR's Avatar
I went to home depot and bought a CH impact wrench, $25. I tried one day and could not get it to budge, even soaking it in liquid wrench. Second attempt worked by soaking, and then heating with propane torch to get the flange on the bolt to expand. Then impact wrench, and came off smoooth. I tried the starter thing, and think it is too dangerous, as my socket split (Impact) doing it!
Best of luck, and yes mine is an auto!
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
