Problems after installing Frankencar midpipe
Old Apr 15, 2003 | 11:07 AM
MaxDoogie's Avatar
I finished installing my Frankencar midpipe this past weekend...I took my car out for a spin after first getting it installed and I was impressed with the torque gains I felt from it. I did a few runs to close to redline and was happy. I then took it home and turned it off and let it sit for an hour or so.
Now, after I went out and restarted my car, it was idling funny (It was already a little rough after I had my custom catback installed). Now when I try to run the car at WOT and the car hits around 4,000 rpm, my car has serious lag...It's like my variable intake won't kick over and won't pull at all...The car will still climb the RPM's, but at a very slow pace, and the car is seriously holding back.
I know it isn't the MAF, cause it will still pull and go to redline, just with the lag and rought idle...I have checked and rechecked and undone and reconnected everything 3 or 4 times now, and still the same problems.
Anyone ever experienced this before, or does anyone have any ideas what could be causing it? BTW, I have a 2000 5 spd
Old Apr 15, 2003 | 11:14 AM
MaximaMan77's Avatar
Re: Problems after installing Frankencar midpipe
Are you sure your wire harness it pluged it good to the maf? No bent leads? and there are no air leaks behind the maf like at the TB? Check these again. Also after checking that disconnect the battery over night with the dome light on.
Old Apr 15, 2003 | 11:20 AM
MaxDoogie's Avatar
Re: Re: Problems after installing Frankencar midpipe
I have done all these things, including leaving my battery undone and pumping the brakes to clear the ECU...All fittings have been checked and rechecked, including the MAF, temp sensor and all apdapters..I am afraid it is something with the actual throttle body or variable intake...
If worse comes to worse, I am going to put the stock midpipe back on, leave my stillen filter the way it was and see how that works...It's the only thing I haven't tried yet.
Old Apr 15, 2003 | 11:29 AM
Re: Re: Re: Problems after installing Frankencar midpipe
1) If it's the variable intake it will pull just as hard to about 4-4.2k 2) If it's the TB you can check the butter fly by having a friend step on the gas while you look into it. 3) If it's either of those 2 then it doesn't matter what you do with the filter or mid pipe you'll still have the prob.
Try going back to stock and see if the prob is still there. If so you'll be ready to go to the dealer.
Old Apr 15, 2003 | 11:35 AM
MaxDoogie's Avatar
Re: Re: Re: Re: Problems after installing Frankencar midpipe
Yeah, that is what I said in my original post...it will pull hard to 4,000 and then the problem occurs...So I am thinking the problem is with the variable intake
Thanks for your info
Old Apr 15, 2003 | 12:00 PM
Re: Re: Re: Re: Re: Problems after installing Frankencar midpipe
Check the vacuum lines on the intake. Also a malfunctioning VIAS should throw a code# P1800
How fast of an internet connection do you have?
Old Apr 15, 2003 | 12:09 PM
chinaonnitrous1's Avatar
its a busted MAF....i'll put money on this one. its not busted yet..but failing.Ive had the same problems berore my 3rd one blew out.
Old Apr 15, 2003 | 12:57 PM
MaxDoogie's Avatar
Re: Re: Re: Re: Re: Re: Problems after installing Frankencar midpipe
I have an extremely fast internet connection here at work (eBay) and a fast connection at home...What do you want to send me.
Anybody got any quotes these days on a new MAF?
Old Apr 15, 2003 | 01:02 PM
MaxDoogie's Avatar
Old Apr 15, 2003 | 01:06 PM
Maf's are about 100 bux or so. If you want to help me out. I have a 2k1 maf here, thats only a few days old. I've gone through about 4 2k2 MAFs. If you wanna buy it Let me know, because i need to get rid of it. Larry
Street Reeper's Avatar
Handsome
+1
Make sure that the vacuum line that connects to the block is tight, did you use a breather filter on this, this is what your problem sounds like.
Old Apr 15, 2003 | 01:21 PM
I can send you that part of the FSM if you'd like. email me if you do.
Old Apr 15, 2003 | 01:41 PM
00SEinMA's Avatar
I just blew my MAF... if your 2000 is a cali emmisions then I believe there is a TSB out for the MAF and the dealer will replace it if you put it back to stock. They said that a new MAF would be $480 for just the part, no labor.
-James
Old Apr 15, 2003 | 01:45 PM
MaxDoogie's Avatar
-James
Sorry, I should have been more clear in my first post...I actually have a fed spec...I wish I had the cali spec since their is the TSB for it
Old Apr 15, 2003 | 01:46 PM
Handsome
-James
Make sure that it is not just K&N oil on the actual sensor, some 5th gens have the signs of a faulty MAF because of K&N oil on the sensor, after they wiped it off everything was fine, you have probably already tried this but thought I would just mention it.
Old Apr 15, 2003 | 02:31 PM
MaxDoogie's Avatar
Actually, it is funny you mention this...I haven't tried wiping down my MAF yet, and the symptoms stared right after I cleaned and olied my k&N...or course I only oiled it lightly, but it is definitely worth a try
hhmm...sounds like I have a new project when I get home
Thanks for the info!
Old Apr 15, 2003 | 02:37 PM
Congratulations your suffering from Lery syndrome.
Maxman2000's Avatar
Disconnect battery?? Why??
Old Apr 15, 2003 | 02:59 PM
MaxDoogie's Avatar
reset the ECU
Old Apr 15, 2003 | 05:46 PM
MaxDoogie's Avatar
ok guys, what entails wiping down the MAF? What exactly needs to be wiped down? The inside of the tube, the electrical connections, the black box or what?
Lemme Know!
Old Apr 15, 2003 | 06:00 PM
Virus's Avatar
Go get the ECU TSB update. It will go away. Mine was doing something similar.
Old Apr 15, 2003 | 06:01 PM
Handsome
Lemme Know!
From what I remember it was the metal thingies that hang down inside the MAF, I have never done this so wait until another person who saw the same post chimes in (and I just called the parts you need to clean thingies) but this will at least bump this post to the top, if that doesn't work you may want to start a new thread, I hope I just saved you $450 because if you just cleaned your filter it is a strong possibility.
Old Apr 15, 2003 | 07:46 PM
MaxDoogie's Avatar
nice, thanks for the info..Is there anyone out there that has actuall done the cleaning...Also, what tool did you use to pull the MAF from the MAF tube...It has security bolts in the tube that lock it down?
Anymore info would be greatly appreciated
Old Apr 15, 2003 | 08:56 PM
Shift_VQ's Avatar
Sorry to sound dumb but I have a Cali spec and was wondering what a TSB is? Anyone?
Old Apr 15, 2003 | 09:31 PM
MaxDoogie's Avatar
TSB = Technical Service Bulletin
It's what they file when you need to have preventive maintenance done to your car...there are various websites where you can go review these TSB's
Old Apr 15, 2003 | 09:32 PM
00SEinMA's Avatar
There is a TSB stickey at the top of the 5th gen form here.
-James
Old Apr 15, 2003 | 11:36 PM
BlueStreak's Avatar
ok i know this may sound weird but when this happened to me i took the filter off and sprayed 3M brake cleaner onto the MAF, let it sit a couple (5min) reattached the filter, started the car and it stopped the hesitation.
Old Apr 16, 2003 | 03:10 AM
02MaXiMa_GLE's Avatar
Huh?.... You're
You never told us what brand & model filter you're using.
G
Old Apr 16, 2003 | 07:10 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
how many miles has it been since then?
Old Apr 16, 2003 | 08:08 AM
MaxDoogie's Avatar
I was gonna try this, but with engine degreaser instead...Brake cleaners scares me, from my understanding, it is one of the most acidic of all the cleaners.
I didn't think that my K&N or oil from the K&N was the problem..I guess I have another project tonight
Old Apr 16, 2003 | 08:20 AM
Maxman2000's Avatar
I got a K&N drop in filter in my car (I use one of those K&N cleaning kits, got it from Autozone) and cleaned it a couple of time and nothing goes wron for me.
Old Apr 16, 2003 | 11:41 AM
MaxDoogie's Avatar
I have cleaned my high flow multiple times, too...all with the same procedure...Maybe the build up of oil finally got to it
Old Apr 18, 2003 | 02:15 PM
MaxDoogie's Avatar
Well, I fixed my car...I was the victim of a dirty MAF...all I did was pull the MAF out, spray some carb cleaner on it, and back to normal!! I am a happy camper right now
Old Apr 18, 2003 | 02:36 PM
Handsome
YEESSSSS!!! You are the second person who has saved $480 thanks to me, someone give me a cookie!!!!
Who's the man
Old Apr 18, 2003 | 03:45 PM
MaxDoogie's Avatar
Who's the man
You da man, Street Reeper!!
Old Apr 18, 2003 | 11:49 PM
BlueStreak's Avatar
well i may be but it looks like it was fixed and btw it has been over 40000 miles since i did it and guess what... im still on MAF number 1.
Old May 12, 2003 | 09:18 AM
TRuFLiPpeR's Avatar
yeah, i donated....so?!?
i wanted to know where i could get maf's for $100?!? is that for the sensor and tube?!? i might as well get spares for that price, the lowest i've seen was from DaveB at around $380! i seriously need one (either 22680-6N200, or 6N201). let me know!
n1cK!
Old May 12, 2003 | 09:41 AM
lcf's Avatar
lcf
n1cK!
PM or email chinaonnitrous1 (Larry). He has a MAF for sale. He's a good guy.
Old May 12, 2003 | 11:57 AM
TRuFLiPpeR's Avatar
i've already gotten in contact with chinaonnitrous1 and he told me to go to daveb. the 2k1 maf won't work on a 2k2...temp sensor. we'll see!
n1cK!
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Tha'-Max
Aug 30, 2015 01:14 AM
kirkhilles
Aug 8, 2015 10:53 AM
