what purpose does this serve?
Re: what purpose does this serve?
Originally posted by guitarn247
reseting the ECU, what purpose does it serve?
Long story short, when the ECU is reset you can start from a clean slate and have it adapt itself to more aggressive driving. Note that this isn't necessary, as it will eventually learn this behavior and adapt over time, it'll just take longer.
Also, if you install some mods (Y-pipe, CAI), I've heard it's a good idea to reset the ECU so it learns its new restrictions (or lack thereof).
Originally posted by Maxman2000
Ok just one more time (your gonna be ****ed of probobly about this) How do you reset the computer.
Stand in front of your car with the hood open
Kneel down and bow to the engine, while chanting "gimme more, baby; gimme more, baby"
Then install an NO2 bottle and kit
Simple, and you'll notice the difference immediately.
Okay, I'm bored. Anyway, the theory on the .org had always been that 5th gen ECU's weren't resettable by disconnecting the battery overnight (other cars can do this). Then yesterday I saw a post about doing that, so...
dunno.But the dealer can do it with their ECU system, which they would probably do for something like $35. And you could have them advance your timing while you're at it
Hey Miximax2, what's your timing set at?? I'm thinking of doin 17 degrees advanced.
According to some other posts, up to 17 is still okay for warranty, but you might ask your dealer for confirmation.
Originally Posted by studman
Thanks,
Bill
JodyBerry: The reset procedure resets all of the "learned" settings of the ECU. It does not revert your advanced timing settings, etc that were done using a Consult-II. When you drive the car after the ECU reset, it will be in learning mode. I have found out that the learning mode is more than 100 miles but less than 200 miles from the reset.
Originally Posted by dobiegillis
I have a stupid question. If I reset my ECU will this change auto transmission shift points? My tranny is way to sensitive and I'd love it if it didn't downshift when I just barely increase throttle.
i read the info on how to reset the ecu, i went outside right away and tried it... but i couldnt get it to work, i might be a lil' too retarded or does this not work for the 2k ??
litch
123
Jan 4, 2024 07:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
NissLover
Aug 22, 2015 10:26 AM
Viralkill
Aug 17, 2015 10:54 AM
