Fog Light re-wire
#41
FYI---If your headlights/parking lights are NOT on, the fogs won't be on either (high beams or not.) What I mean is if you are flashing your high beams during the day by pulling the blinker lever towards you then the fogs will not come on. They will only work when the parking lights are on.
I can't say for sure the wiring is the exact same on a 2k2. Can anyone else with a 2k2 compare with my photo?
#42
#43
Originally posted by ynot411
They actually go off when the high beams are activated. I did exactly what your directions say.
If you want that functionality then it probably won't be a simple re-wire at this point. The parking light rewire you did overcomes the + relay input for the DLs, but I'm guessing that the high beams cut the - side of the DL relay, which I will have to research to confirm. This could very well involve a relay and could be much more involved.
How far do you want to get into this my friend?? This will go beyond a "simple" change to a much more involved one that you may not feel comfortable doing unless you're electrical.
Considering the amount of questions you have asked I assume you are not able to troubleshoot this stuff and may very well get in over your head.
Just a suggestion....
#45
Originally posted by killer2002SE
but what if i want to have the fogs on in the auto position int eh daytime and ahve the parking lights off and the headlights on and the corner light on??
lol j/k
lol j/k
*shrug* Guess I can't be right all the time!!!
#47
#48
Originally posted by studman
There are 2 answers to that question. Yes and No.
Yes: Anything is possible. It would require an extra relay to be inserted in the parking light circuit before the parking light relay in the relay box shown above. But read the "No" section as to why you won't do this.
No: Because if you do that, all your side and rear marker lights no longer light up, which (at night) is dangerous AND illegal. You WILL get pulled over if you do this.
Yep. I do. And I STRONGLY recommend AGAINST it. Keep with what the instructions say and wire it up to the parking lights.
Actually there is another way around this..... just take out the light bulbs!
~limsandy
#49
is there a way to rewire the parking lights to not work when the main headlights are on?
But still... it's another way that is possible. And I'm sure there are many more. Wiring the fog light relay to the battery (or ignition-switched source) and pulling the parking light fuse (or relay) is another way to do it. And so on... and so on...
#50
This is by design. The entire voltage load of the low beams, high beams, fog lights, and all the parking lights is too close to exceeding the amperage for the lighting circuits in the car. So Nissan played it safe and had the high beams deactivate the fogs whenever the high beams are used. I would not recommend changing this, as an electrical short/fire could be caused if all the bulbs were lit up at the same time (over a period of time which is yet to be determined).
Also, I haven't tried it yet but it seems if you wanted to get the fogs to work with the high beams you would have to track down a green/yellow wire from pin 32 (2K-2K1) @ the fog switch. You'd cut this wire and attach pin 32 to gnd. You'd then attach the other half of the wire to green/orange @ pin31 (2K-2K1) of the fog switch (other side).
SHIFT_woosh
#51
maybe you electrical guys acn help us here...
https://maxima.org/forums/showthread...hreadid=211665
#52
#53
Ok guys, here it is (for the 2k3'ers), prolly the same for the 2k2:
I took mine apart again so I could notate it.
I cut and spliced the BLUE w/SILVER DOTS wire (no white stripe, fog light relay) into the RED/GREEN stripe wire (parking light relay output.) Be sure you tape (seal up) the wire you cut and not use (I soldered mine). I would recommend you solder this if possible--wire taps sometimes damage the tapped wire, over time they corrode and can lose their "bite" on the wires (I used to be a Car Audio/Security installer, I can't even begin to tell you how many wire taps I had to replace to fix issues on customer cars.)
THIS ALLOWS THE FOG LIGHTS TO SWITCH ON AND OFF WITH THE PARKING LIGHTS. The factory fog switch still works.
I took a pic too just for my .ORG buddies (if someone wants to pirate my photo, feel free. I don't have time to build a instruction page.) I think this pic eliminates any confusion.
#2 Do you solder the blue/siler wire to the red/green wire or do you solder the other cut part of the wire?
#3 By just wiring the blue/siler wire to the red/green makes the fogs work with the parking light? And still makes the factory switch work too? Or do we need to cut more wires?
#54
Originally posted by silvermaxima2k3
I have some questions.... Number one... what is a tapped wire?
2. I think the pic is self-explanatory. I soldered both. Solder won't corrode like copper.
3. Yes. Yes. No. Only cut the blue/silver and splice into the red/green as shown in pic.
#55
1. The "tapped" wire is the source wire that you are splicing into.
#56
Originally posted by 2001SE
is there a way to rewire the parking lights to not work when the main headlights are on?....so when you look at the car from the front all you'll see is white lights of the H4 and the H3 fogs. but when i blink it will blink too
does anyone knows what i'm talking about?
This is copied over from the How-to sticky. (thanks to IceY2k1)
STEALTH Running Lamps(FREE Mod)
Eliminates the AMBER running lamp filament on the 1157 bulb used for a 2K-2K1 headlamp, but still uses the blinker filament. This mod makes the headlamps only produce white light until the blinker is activated, which looks better in my opinion especially with clear front corners.
1)Remove the bulb/socket from the headlamp housing.
2)Remove the bulb from the socket.
3)Place SMALL piece of black electrical tape over ONE "knub"(small contact on bottom of bulb).
4)Reinstall bulb into the socket.
5)Turn on hazards(or blinker with keys in ignition). If it flashes reinstall bulb/socket into the headlamp housing, if not, remove bulb from the socket and move the electrical tape to the other "knub".
#57
Fogrewire mod - can't find a good link
Howdy, folks! I've tried to follow both links to the "Fog Rewire" write-ups, but come up empty-handed on both (404 not found ).
Does anyone have the write-up that could fire off a round to me?
I'm driving an '02 I-35, so I think the wire is blue from what I've red (as opposed to yellow?)...
I'm pretty certain I can figure it out, but I don't want to toast anything!
I've got PIAA fog-lights and RAZO high-beams, so I'd like to take my HID's out of commission during the day. I have always driven with my headlights on as common sense because I live in South Carolina and we have more wrecks per mile than any other state, so I've been told.
(ratledge@cs.com)
Thanks!
(ratledge@cs.com)
Thanks!
#58
Re: Fogrewire mod - can't find a good link
(ratledge@cs.com)
Thanks!
(ratledge@cs.com)
Thanks!
Dang rookie - nobody fire on me, now - I've got my Nomex suit and a flamethrower handy just in case. I didn't read the thread from top to bottom. I feel like the old "Saturday Night" skit: 'nevermind'...
#59
Re: Re: Fogrewire mod - can't find a good link
#61
I finally done mine. Soldered it too.
On 2k the fog wire is not blue like on your's, it is yellow with two silver dots. The rest is exactly the same.
Thanks again.
The Frye
09-02-2021 12:03 PM
fastcarny
10-06-2015 11:42 AM
-ReLLiK-
09-08-2015 01:02 PM
Maxima30
09-07-2015 07:13 PM
