Replacement rotors?
Old Apr 28, 2003 | 07:41 AM
GXEme's Avatar
Replacement rotors?
Anyone have any recommendations for replacement rotors for my 2000
Maxima? Should I go with OEM replacements via Courtesyparts.com or
local dealer. Or should I get my replacements from an aftermarket such
as Napa, VIP, Autozone, etc?
In case your wondering my car is producing quite a big of jitter
during highway speed braking.
Old Apr 28, 2003 | 09:38 AM
T-bone's Avatar
I would NOT replace OEM rotors with OEM rotors, because they will probably warp, too. I recently replaced a rotor with a Brembo blank. I bought it at a local imported parts dealer for about $65. Nissan wanted a lot more than that! When I compared the Brembo to the Nissan rotor, I found the Brembo to be better reinfrorced to prevent warping. The local auto part chains did NOT have replacement rotors in stock. Rotors for our 2000 only fit one other year (2001) so there is not much demand for them. When I contacted the auto part chains, they did not have any in stock.
Check out the Group Deal area to see if there are any bargins on Brembo Blanks. Also, check your local parts stores. Good
luck!
Old Apr 28, 2003 | 11:06 AM
Padsy's Avatar
Boost.....
Brembo or Stillen....I've got $tealin
Old Apr 28, 2003 | 12:11 PM
GXEme's Avatar
So these are bolt on replacements right? Are there any good online vendors for these parts?
Thank you
Old Apr 28, 2003 | 12:14 PM
Padsy's Avatar
Boost.....
Thank you
southwestautoworks.com
Old Apr 28, 2003 | 12:20 PM
2001SE's Avatar
check the Group deal fourm. there is a zinc Brembo deal going on for pretty cheap,
just dont get OEM
Old Apr 28, 2003 | 12:30 PM
T-bone's Avatar
just dont get OEM
those are not Brembo BLANKS.
Look for the post about buying Brembo blanks from NOPI.
Old Apr 28, 2003 | 01:03 PM
GXEme's Avatar
Hmm, this is what I get when I click on the search link,
"You are not logged in or you do not have permission to access this page. This could be due to one of several reasons:
You are not logged in. Fill in the form at the bottom of this page and try again.
You do not have permission to access the page that you were trying to. Are you trying to edit someone else's post or trying to access administrative features? Check that you are allowed to perform this action in the Forum Rules.
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation. "?
Any other ways to search for NOPI?
I put my name up on the group deal too, so I'm hoping to hear back on that one.
Thank you
Old Apr 28, 2003 | 01:18 PM
Colonel's Avatar
Old Fuddy Duddy
Make sure
You dont use OEM pads. I have verified for SURE that my vibration is due to materials EMBEDDED in the rotor surface as according to theory here:
Brake Myth
Old Apr 28, 2003 | 01:31 PM
GXEme's Avatar
Just read the Administrative announcement: about the search feature. If anyone can help with this I've already contributed to Maxima.org?
Quantity: 1
Item Title: Maxima.org Donation
Item Number: 1000
Date: Jun 9, 2002
Time: 3:02:12
Status: Completed
Old Apr 28, 2003 | 01:36 PM
Colonel's Avatar
Old Fuddy Duddy
Quantity: 1
Item Number: 1000
Date: Jun 9, 2002
Time: 3:02:12
Status: Completed
Originally posted by Jane97SE
Until the server move is completed, those who donated will not be able to gain acces to the search feature. This applies to donations made after 03/23/03. Sorry for the inconvenience.
If you have donated, your donation is going towards the new server and access to the off-topic forum when the server move is complete.
Any emails regarding the search feature (i.e. why has the search been turned off?, why are you making me pay for the search?, etc.) will be deleted.
BTW, we are NOT in any way "making" you pay for the search. If you want to help the site out, then we thank you. But, if you want to ***** and complain about the search..take it somewhere else.
Like Ragu....its in there baby!
Old Apr 28, 2003 | 01:41 PM
Colonel's Avatar
Old Fuddy Duddy
Thank you
It was only on the second page of the GD section ?????
Brembo Blank Thread
Old Apr 28, 2003 | 04:20 PM
KennyLau
Re: Replacement rotors?
Has anyone ever shopped at www.drivewire.com for anything?
They say they have stock of Brembo rotors (blanks) and they offer free shipping on orders over $50.00 within the continental United States. Right now, they have the following Brembos...
Front - $52.57 each
Rear - $31.50 each
I was going to order the rotors from NOPIOnline.com, but I've read that they don't always have stock of things.
Old Apr 28, 2003 | 05:36 PM
Max_5gen's Avatar
If you're going to replace your rotors and also going to replace your pads too AND have some curiosity - could you start from replacing just pads? I'd recommend R4S or Raybestos Quiet Stop, your pick. If you go with anything else - do your own research, I have no idea. I've been using stock set + R4S for more than two years without problems. Make sure also that the rest of brakes are fine, mostly caliper sliding pins should allow caliper to move, their rubber boots often crack, grease goes out and they stick inside pretty hard. If that's the case new rotors/pads won't last for long either.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
A32goldylocks
Sep 2, 2015 06:39 AM
RealityCheck
Aug 5, 2015 06:18 AM
