2k-2k1 smoked taillights in a 2k2
Old May 1, 2003 | 06:17 AM
hombre's Avatar
I think I read somewhere that this is an easy switch. True? And if so, would anyone be up for trading their smoked lights for my 2k2's?
Old May 1, 2003 | 06:22 AM
billyman's Avatar
hombre,
I have a 2k and would like to trade you my smoked tails. I sent you a PM. Holla back.
Old May 1, 2003 | 06:32 AM
Igor911's Avatar
try to make a post in the FOR SALE section of the org. You will have more of the correct audience there.
Old May 1, 2003 | 06:52 AM
255HP_03_SE's Avatar
Re: 2k-2k1 smoked taillights in a 2k2
It is a direct swap... INCLUDING the wire harness and bulbs. You can't use the wire harness and bulbs from a 2k on a 2k2 (and vice versa).
The hardest part is prying the light off with all of that sticky black glue...
-R
Old May 1, 2003 | 08:56 AM
billyman's Avatar
Re: Re: 2k-2k1 smoked taillights in a 2k2
-R
Ok, I'm a wee bit confused here. Did you mean to write "You can use the wire harness and bulbs from a 2k on a 2k2 (and vice versa)."
Please clarify. Thx man.
Old May 1, 2003 | 09:32 AM
hombre's Avatar
He's saying if we make the swap, send the harnesses as well as the lights.
BTW, sent you a hotmail.
Old May 1, 2003 | 09:44 AM
Old May 1, 2003 | 12:47 PM
Bobalouy's Avatar
I would also be will to trade if they fall through.
Anthony C
Old May 1, 2003 | 01:21 PM
asu174's Avatar
Clay Aiken has fancy genitals
Yes it works. Plug and play. Here is a pic of my 2K2, which I also swapped badges on.
Old May 1, 2003 | 04:02 PM
billyman's Avatar
Hombre, I sent you an email. Looking forward to the swap.
Old May 1, 2003 | 08:23 PM
GeSeKeE19-'s Avatar
i also have a sk2 maxima se that i just bought 3 days ago. i am also looking to trade my taillights for the 2000 maxima SE blackhoused taillights. let me know if anyone is interested in making a swap with me.
Old May 2, 2003 | 06:14 AM
Bobalouy's Avatar
PMed you GeSeKeE19
Old May 3, 2003 | 08:17 AM
MoCoMax's Avatar
I did this swap with a fellow org member about 2 months ago. I traded my smoked 2K SE tails for his clear 2K3 tails. They are a direct swap - no wiring issues at all.
The hardest part is breaking the seal of the rubberized sealant used between the light housing and the body of the car. Once you pull the 4 nuts off the inside of the light, you'll need a long bar of some kind to prop inside the trunk and place pressure against the rear of the light housing. It takes a fair amount of pressure and a little patience - keep steady pressure on the light, but don't force it - the bond will break, but it takes some time.
Just make sure you pick up a replacement for the seals before you pull the lights - the old seals may or may not be reusable, depending on their condition when the lights get pulled off. Also, the seal is like tar - wear gloves, and keep the crap off your paint.
There is no wiring to do - simply unplug the lights, swap them out, and plug them back in. It's literally as easy as that.
TallTom
57
Oct 14, 2025 05:16 PM
homewrecker
Sep 24, 2015 07:01 PM
ballerchris510
Sep 10, 2015 09:35 PM
JoshG
Sep 5, 2015 10:10 PM
